CNX Nano2 New dongle, Off Service, won't register
Username: Adam_paul
Post Number: 42
Folks on CNX Nano 2, I uploaded new 8.06 factory file, than also firmware 1.28. It finds the IP address but whne go to IKS registration, its giving an error and not registering. Any help please? Anyone has similar problem and has the solution?
Username: Lklives
Post Number: 16120
CNX is down now...thats why the error and not registering...I suggest U join this site, and read....its a free good site, and has all the files , guides, help, and chat, that U will ever need..
http://www.ftabins.net/forumdisplay.php?f=452
Username: Lomna
Sac, Calif U.S.A
Post Number: 929
LK, registering has nothing to do with down thing. It is up here friends. I never even upload firmware 1.28
Working great with 1.26.
adam try firmware 1.26 lets see what happen...
adam, remember you must keep trying registering even you getting error. It will eventually do it Good luck.
Username: Plymouth
Post Number: 12894
Adam
Please do not listen LK!
We can help you on eCoustics much faster than ftabin!
Lk poor idiot, return to your hibernation!
Username: Lklives
Post Number: 16122
there are over 100,000 ppl at http://www.ftabins.net to help U that actually KNOW FTA , unlike here....
Username: Lklives
Post Number: 16123
C/P
IKS Registration problem
Guys,
I had the same problems The registration really it don't give a hoot...
But when the server goes down and you try to register it... It will
stand up and say Oh no you don't and give you a big nasty CNX error..
But once the server comes back its fine.....
Just make sure to have your router set up properly to support your static or ip settings
Username: Chacha_chaudhary
Post Number: 24
Just leave it on channel 200 for 45 minutes. Dont touch the remote, u will get it back.
Username: Plymouth
Post Number: 12896
Over 100,000 peoples will not tell that they are all able to help!
In good Viewsat time many site copied their info on eCoustics!
Same thing for Nfusion!
You can't post your sh1t on ftabins, that's why you are back!
Username: Adam_paul
Post Number: 43
chacha chaudhary, when you say working channel, could you please inform that channnel number 200 and on what ECh** YOU ARE HAVING THAT CHANNEL? 110, 119? Please help
Username: Plymouth
Post Number: 12897
Adam
chacha do a joke!
Try what Devin said on above post!
Username: Adam_paul
Post Number: 44
plymouth, I tried uploading 1.26 but it won't take it. It says "upgrade with latest software". So, that did not worked. I am trying now to register even though I am getting "error' over and over again. Its frustrating but right. I am doing as per Devin.
BTW: is there any loader software that I can use to upload factory bin using RS 232 cable? May be than it will take 1.26 file?
Username: Plymouth
Post Number: 12898
Adam
Load the factory bin then try again to load the 1.26
You can found the loader then the file at Conaxsat home:
http://www.conaxtech.com/support_app.shtml
Username: Lklives
Post Number: 16124
no joke..put it on channel 200, and wait!
Username: Plymouth
Post Number: 12899
LK
Lol!
Are you serious!
Can you tell me why his receiver will be back if he wait on this channel!
Wait on any channels will do exactly same thing, the receiver send a request to server each 12 to 25 seconds, with no regard on the channel you selected!
A router and modem reset will be much better thing to get the server!
Username: Lklives
Post Number: 16125
Plymutt..if ya actually did some reading U would MAYBE have a wee bit of understanding....BUT nope, U're a fuktard instead!
Username: Lklives
Post Number: 16126
CNX Nano2 Setup guide
There are "issues" today with registrations...but ya don't need it to watch TV...reboots etc have been tried, but the most common solution had been leaving it on channel 200 for an hours or so, to regain TV, if your setup is correct...also its believed that the CNX server may be the culprit....and 1.28 has been working fine..some have TV, some don't..both DN abd bev..this is an intermittent issue with both new and old testers..
