Punjabi channels are also came back up on k1plus/pro..
Username: Saqeeb9000
Post Number: 6379
lots of people were asking for this.. enjoy
602 punjabi tv
809 jus punj
822 mh1
622 alpha etc
Username: Rafiq128
Post Number: 226
Very good sada. Again Thank you for this information too.
Post Number: 6380
u are welcome bhatti,
i guess 3 rec's are competing each other..
nfusion, k1plus, cnxnano2
Username: Rafiq128
Post Number: 227
Nfusion has all the channels except
674 indus music
678 indus vision
These 2 channels are not coming on nfusion. All other indian and pakistani channels are ok
Username: Jdhillon
Brampton, On
sada can i get the tp's for these channels. i am missing a few [mh1]
Post Number: 6381
12142 R
tp 29
DVB
SR 20000
FEC 3/4
this is a good guide if u are missing lots of channels,
but u can still do mannual scan..
First turn off the "TP Auto update". then setup your LNB to universal with frequency 9750- 10600. Do a blind scan. You should and will get all the possible channels. Some of them will be repeat entries. don't worry about that. the repeat entries will go away after a power off/on. After that, if you ever need to a rescan, just do auto scan.
This solution works perfect every time. One minor inconvenience is to keep the TP update off; not a bnig deal.
Just, wanted to share
Username: Kingofdakingz
Post Number: 500
sada paji ur the best man
Username: Nydas
Post Number: 16847
Jeete raho.
Username: Leo_here
Brampton, ON Canada
Post Number: 168
Jeeo !
Keep up the good work like this !
Post Number: 6386
thanks guys for kind words..
Username: Dghumman
Ontario Canada
Post Number: 337
thanks sada you will get lots of blessings from the old people who can watch Gurbani live
