so you need both viewsat satellite receiver and K-box satellite receiver to set up indian channels? I already have dish network antenna connected. I am trying to figure out what is needed?
jaisan, buy cnx nano 2 u will get same amount of channel, return ur old sat rec with remote .. any rec viewsat, pansat etc with remote and u get $ 40 off, it cost $ 170 on sat depot..
1. Broadband Internet connection. 2. Kbox Prodigy with khub or one of the NEWER Nfusion recievers - not Nova. 3. Router if not there. 4a. Cable from router to khub or Nfusion. 4b. Alternative to using a cable is a wireless bridge if you have a wireless router. 4c. Alternative to cable and wireless bridge is two powerline adaptors. For information on all these see
http://www.currentbins.com
You should install using a dishpointing software such as http://dishpointer.com They usually come with a small USB drive, otherwise, you should buy one
so i looked around and Nfusion Phoenix seems like the newest product on the market. I already have an antenna from Dish Network installed; however, the direction might not be right.
so what else do I need to buy besides Nfusion Phoenix? I have LNB connected to my dish..not sure if it is "Special LNB for 118.7W 9Anik F3 ".
Also, it seems that satellite receivers don't work in America anymore because of some Nigravision 3 issue. I've no idea what that is, but I read about it on currentbins.com. Does anyone have anymore info?
dailumantus do u have sat internet? with which company?
which channels are u currently getting with dn? are u getting any indo/pak/ international channels with current dish?
u have no idea about sat rec? u have no idea about iks read about what is iks what is nagra 3 which rec are working which are not working which channels are u interested.?
