Gold Member Username: Saqeeb9000Post Number: 6305 Registered: Oct-07 | hi just heard from my freind that lots of new channels will be comming soon through iptv, i guess new technonolgy like jadoo tv, he said quality would be aweomse, this new iptv channels will be comming to canada, channels will be including.. ten sports... geo super and lots of other channels that are not available through dn or bev..\b he said it would be way cheaper than dn or bev..bu t not free |
Silver Member Username: Lubfr01Post Number: 150 Registered: Sep-07 | Sada ... you nfussion has all desi (indo./Pak) channels up? If it is not nfusion what do you have and which box has these channels up (in USA)? Please help... |
Platinum Member Username: PlymouthCanada Post Number: 11775 Registered: Jan-08 | Sada Many channels are free on: Why paid for free TV channels? |
Platinum Member Username: NydasPost Number: 16759 Registered: Jun-06 | There used to be a big difference in favour of kbox in terns of availability of desi channels. Now there is not much of a difference, but kbox still has a few more. Also some desi channels will scan from 61.5 as well on kbox. I don't know if that is true of Nfusion. | |
Bronze Member Username: Sfh99TorontoCanada Post Number: 40 Registered: Jun-06 | question: jadoo tv is taking videos from internet stream. whats the difference between watching idesitv or jadoo tv. I have waiting time and connection lost on idesi tv frequently. does jadoo tv has the same problem? OR does jadoo tv have dedicated servers for international progrmming? which never go offline or waiting period to uplaod the video/buffering? |
Gold Member Username: Saqeeb9000Post Number: 6306 Registered: Oct-07 | frank,.... cnx nano2 , k1plus, nfusion solaris phoneix all good, check channels list , how much u wanna pay and go for there, if i was going to buy something, i will buy cnx nano 2, its new,.. u have to pay only $ 160..channels are stable, i won't switch to nfusion, unless i wanna go for nfusion hd, |
Gold Member Username: Saqeeb9000Post Number: 6307 Registered: Oct-07 | farhan, with jadootv, u can watch it on ur tv, without pluggin any cable etc, i went to store to check it out about this jadoo tv, guy had 42 inch tv, pic quality was crap i mean compare to my k1pro, or any other fta rec i haven't seen any connection problem , the guy told me u have to download channels from internet, tried geo news ,wasn't working , asked him why he said he don't know.. other thing about jadoo tv, lets say u wanna switch channel, its not same as using up /down channel from ur other fta rec, its u have to go back and tune in to different channels, which takes 2 to 3 minutes, to tune in to that.. so from my experience i prefer fta rec compare to jadoo tv, u will get problems because its all through interent, so unless u have no dishes outside ur rec etc go for jadoo tv, other wise if i was you i won' t pay $ 270 compare to jadoo tv cnx nano2 $ 160 nfusion phonix 200 k1plus/pro 200, they have much better picture quality are stable, easy to use and much faster than jadoo tv.. hope it helps you to make a right choice.. |
Gold Member Username: Saqeeb9000Post Number: 6308 Registered: Oct-07 | plymouth those channels that i am talking about you will be able to watch on tv, throught some kind of iptv box, and idesitv.com is not 100% stable, |
Platinum Member Username: PlymouthCanada Post Number: 11777 Registered: Jan-08 | sada idesitv.com is stable for me but I do not listen it for long since I do not understand this language. I heard that IPTV from Jadoo was not stable. So you can hook your TV on computer and listen with it. |
Platinum Member Username: NydasPost Number: 16761 Registered: Jun-06 | jadoo TV was very promising. It turns out that picture quality was crappy and then they discontinued many desi channels. At present, my recommendation is not to touch it at all. If there is new service available using similar technology, the difficulty will be that it is a continuous stream from abroad, and changing channels might not be easy. At present, your only reasonable solution for desi channels is kbox or nfusion. Sada has acquired a CX nano 2 - It is slightly cheaper and has better support. I don't know about the availability of Desi channels. |
Gold Member Username: Saqeeb9000Post Number: 6309 Registered: Oct-07 | nalin i got it and my freind took it from me .. he said i already got k1plus and i can always bid ..lol so i will get one more soon, anyways i went to his house, took me 10 minute to set it up, he is very happy, he said channels are stable, + he has tvone, dawn news and one are two extra channels that are missing on my pro.. |
Platinum Member Username: NydasPost Number: 16763 Registered: Jun-06 | sada: Since you have access to kbox, nfusion and CX nano, it would be nice if you put out a comparison chart of at least the available desi channels., | |
Platinum Member Username: PlymouthCanada Post Number: 11778 Registered: Jan-08 | Nalin Sada has a Nfusion Nova which is dead! Nfusion added many new channels, I can't get 118.8W to give you a good comment on International channels but many list are available, for me Nfusion is the best of all with a very good list on Bev which is very stable without freezing. |
Gold Member Username: Saqeeb9000Post Number: 6310 Registered: Oct-07 |
Gold Member Username: Saqeeb9000Post Number: 6311 Registered: Oct-07 | having problem with microsoft 2007, | |
Platinum Member Username: NydasPost Number: 16767 Registered: Jun-06 | It downloads as .unk file! "Once a file has been corrupted and converted into an .UNK file then there is no way of recovering the original file or reading its contents." |
Silver Member Username: MrgregPost Number: 433 Registered: Dec-07 | sada,where did you get the Nano2 for $160. | |
Gold Member Username: Saqeeb9000Post Number: 6313 Registered: Oct-07 | greg i got mine for 130..on ebay..but gave it to my freind, but lots of stores are selling it for 160, cnx has offer , return any old stb, pansat, viewsat etc and get $ 40 off ..http://www.conaxtech.com/dealers.shtml and call the dealers.. |
Silver Member Username: MrgregPost Number: 434 Registered: Dec-07 | Thanks sada. | |
Gold Member Username: SatgrlDil Mei DarD a Jaga ... Post Number: 1846 Registered: Oct-07 | man kab yeh nagra 3 fix aayegaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa ..its been long time | |
Platinum Member Username: NydasPost Number: 16770 Registered: Jun-06 | Ayega.....Ayega... Ayega aane wala, Ayega......................Mahal. |
Bronze Member Username: Sfh99TorontoCanada Post Number: 41 Registered: Jun-06 | Thank You Sada for the detailed answer. It means that this so called jadoo tv box will increase the bandwidth of our ISPs as its downloading from internet, not to mention the crap quality of channels streaming over internet. I wouldn't go for that , thats for sure. The CNX NANO 2 , does it need dongle?. I believe if you buy a CNX NANO you do need a dongle which is about 100 bucks beside the receiver cost. P.S. Please update the comparison list. I coudn't open even in Notepad ++ or XML viewer. Thanks |
Gold Member Username: Saqeeb9000Post Number: 6315 Registered: Oct-07 |
Gold Member Username: Saqeeb9000Post Number: 6316 Registered: Oct-07 | farhan cnx 2 dongle is included in price.. u don't have to pay any extra, its just small dongle,.. |
Platinum Member Username: NydasPost Number: 16777 Registered: Jun-06 | sada's file above is a .docx file. It downloads as .unk file. You have to rename it to .docx, and open it under Word 2007 or under Open office. Sada: I was hoping for a comparison chart of Indo-Pakistani channels |
Gold Member Username: Saqeeb9000Post Number: 6317 Registered: Oct-07 | nalin the problem with channels are that they keep changing, but all 3 brands gets almost all the indopak channels.. |
