Bronze Member Username: Kowarrior1980Post Number: 25 Registered: Aug-09 | Seems to be down eternally. Never worked even once. |
Gold Member Username: Saqeeb9000Post Number: 6296 Registered: Oct-07 | nope,,, it used to work 1 mth ago then it was down and never came back.. |
Platinum Member Username: NydasPost Number: 16749 Registered: Jun-06 | Anybody tried bin 203 or 201 as suggested by Pannu? |
Gold Member Username: Saqeeb9000Post Number: 6299 Registered: Oct-07 | nalin what happens when u use 203 bin? i can't remember pannus' thread.. |
Platinum Member Username: NydasPost Number: 16750 Registered: Jun-06 | I can't remember the thread, but he posted it 2-3 days ago. He has been cursing kboxes for a long time and as soon as 212 and 213 announcements came he was complaining. Then he suggested 203 bin, which in his opinion was better and had more channels. Then a day later he suggested 201 as a last resort. I can't try it out as I do not have the receiver. Try at at your own risk, but it should be OK to try. I would test it if I had the receiver. |
Gold Member Username: Saqeeb9000Post Number: 6300 Registered: Oct-07 | i mean i can test it after the ufc.. if it gives more channel... if u can post his thread.. yeh bin 212 and 213 had problems but 214 is working great.. |
Platinum Member Username: NydasPost Number: 16751 Registered: Jun-06 | https://www.ecoustics.com/electronics/forum/home-video/602929.html https://www.ecoustics.com/electronics/forum/home-video/602062.html Posted on Wednesday, November 11, 2009 - 07:48 pm: (john '" loverboyz) Posted by Pannu on Friday, November 13, 2009 - 12:06 pm: so yup.. put 212 in and then put 203 back and everythin works with no TP problems!! |
Gold Member Username: Saqeeb9000Post Number: 6301 Registered: Oct-07 | ok.. yeh i think those were the problems when every one using 212-213 bin , after 214 bin, i didn't hear any problem, punjabi channels are not up for long time.. so they haven't add those channels yet.. |
