Username: Asplover Post Number: 177 Registered: Jun-06
Wednesday, September 30, 2009 - 17:59 GMT I heard that KBox Prodigy with KHub works with only specific wireless routers. Is this True ?? I have Wireless TrendNet router and want to buy KBOX prodigy. Now I don't want to run the wire b/w router and KHub. So either a bridge or some kind of adapter will be used. Please give me your good advice.
Username: Sump Post Number: 442 Registered: Aug-09
Wednesday, September 30, 2009 - 18:07 GMT all box have issues with some .. use power line adapters
Username: Nydas Post Number: 16236 Registered: Jun-06
Thursday, October 01, 2009 - 00:00 GMT This is only some info on Trendnet. The URL to get into the router flash is usually 192.168.1.1 Admin admin You can change the built in IP later. You can change it back to factory setting by pressing in a hole in the back with a blunt pin.
Username: Sump Post Number: 461 Registered: Aug-09
Thursday, October 01, 2009 - 00:05 GMT there seems to be no problems with linlsys, netgear or dlink..
Username: Xtrawest Canada
Post Number: 325 Registered: Nov-05
Thursday, October 01, 2009 - 08:46 GMT i'm using kbox hooked with TRENDnet router and seems to be working without any issue
Username: Sump Post Number: 480 Registered: Aug-09
Thursday, October 01, 2009 - 12:49 GMT cool thanks for the update !!
Username: Asplover Post Number: 178 Registered: Jun-06
Thursday, October 01, 2009 - 18:04 GMT Xtra, thanks a lot. I am happy , i am going to buy KBOX soon, who is a good authorzied dealer for KBox, in Mississauga / Toronto Canada
Post Number: 326 Registered: Nov-05
Thursday, October 01, 2009 - 18:12 GMT Following 2 are listed as an authorize dealers in that area on kbox's official website. Angel Electronics 1515 Matheson Blvd. E., Unit B13 MISSISSAUGA, ON L4W 2P (905) 602-1382 SelectSat Electronics BRAMPTON, ON (905) 451-5992
