How to connect two recievers?
Username: By2006
hi , i have tow recievers , i connect both of them ,for tow rooms, the problem is if i turn the first one i loose signal on the secend one please help,
Username: Plymouth
Post Number: 11056
said aozal
You can't use both receiver on same LNB, you must use LNB with 2 outputs.
List the satellites that you use and we can help you to make that it work.
Username: Sump
Post Number: 400
depending on your actually setup some higherer end switchs can work also to distribute the signals to several boxes
Username: El_toro_the_great
NC USA
Post Number: 101
said aozal..........run a cable from each out put directly to each receiver...no switches!...you only have 1 LNB no need for switches
Username: Sump
Post Number: 408
yes you WILL NEED 2 switches !!1!!!
2 4x1's like DUH !!
or only 1 LNB per box
Username: Sump
Post Number: 409
DOHH !!
Username: Justforhahas
Post Number: 1859
Much more info needed...list all hardware (LNB's # and type, switches type, receivers# and type) and cable configurations from dish to each receiver...receiver settings...etc....many variables will cause 2nd receiver to not work..
once you identify the specifics and details of your setup, the problem can be resolved..
Username: Sump
Post Number: 410
I THINK WE HAVE A FAILURE TO COMMUNICATE !
shakin it boss
Username: Tapeman
New York Citay in-HD, NY
Post Number: 4425
Whisky
STFU
Yo know nothing about LNBs
That Aspen is a circular dual LNB
Yo have no clue what satellite he's using
If he follows yor advice and buys that Aspen it may not work if he's pointed to 97W if that happens to be the bird he's got
Can't yo see this is his first post?
Typical 14 year old TFR
said aozal
From what yo described
It sounds like a single ouput LNB feeding to receivers
Or somehow Yor Sat Signal is split
Since yo can't split V & H Polarities with one Coaxial
What yo need is a dual LNB similar to the LNB in Photo by that Retard
One to each receiver
Playmoth and Justforhaha are right
Don't pay attention to other clowns
Listen only to senior members
So give us more detail to guide yo with best solution
Username: Plymouth
Post Number: 11058
Playmoth!!!!!!!!
Username: Sump
Post Number: 412
king you have such a suttle way of putting things into perspectives !!
Username: Tapeman
Post Number: 4426
Sump
This is a long story
This idiot has over 12 nick names
Always like to challenge me despite his knowledge & IQ at lowest on earth
He's always wrong
He reminds me with Katy Perry's song:
Yo change your mind
Lika girl changes clothes
Yeah, yo PMS lika b!tch I would know
Yeah, yo always think ...Always speak cryptically
I should know....That yo're no good for me
Cuz yo're hot then you're cold
Yo're yes then yo're no
Yo're in and yo're out
Yo're up and yo're down
Yo're wrong when it's right
It's black and it's white
ta tata tata ta ta ta....
And verse repeats few times
Username: Mrskullz1
New York
Post Number: 1235
lmao
Username: Nydas
Post Number: 16180
said aozal: You may not find it easy to change the LNB. I am a practical person, and there is always the likelyhood of your needing additional dish or LNB for another sat.
I suggest therefore that you buy a simple 3 input 4 output switch. This kind of switch allows you to have three satellites coming in and distribute them to any of 4 receivers.
You may be able to achieve the solution inside the house, by attaching the new 3/4 switch inside the house and connecting the two receivers. You will be using only one of the three inputs.
The ideal place for a switch like the 3/4 is close to the LNB. Buy a short cable (three to four feet will do) with appropriate ends to run it from the LNB to the switch. Connect your current cable to one of the outputs and run a second cable from second output to second receiver.
Try in the house method first and if not successful try the second method on the roof.
Username: Sump
Post Number: 415
this has already been said twice ...
Username: Nydas
Post Number: 16187
sump: excuse me, but you said he will need two switches without specifying any switch. Now kindly let this guy look at my post and see if he understands and wants to go that route. There is no need to interupt when very specific advice is being given.
Your advice of
"yes you WILL NEED 2 switches !!1!!!
2 4x1's like DUH !!
or only 1 LNB per box"
is erroneus to say the least.
Username: Sump
Post Number: 421
nalin your ingnorance is showing ....
you have obviously never setup a box before
what is a switch used for in FTA ?
why do you get a 4x1 switch with your reciever ?
my post is the most correct !!!
YOUR post makes no sense
go read up on switches f'''in retard
Username: Sump
Post Number: 422
here
http://www.nfusionforum.com/forum/showthread.php?t=6104
Username: Gregraf
Post Number: 3527
Username: Nydas
Post Number: 16192
sump: For your education.
"why do you get a 4x1 switch with your reciever ? "
You get a 4 x 1 switch so that you can have four LNB inputs in the switch, and channel them into your newly acquired receiver. That is what I found your answer puzzling. This guy want to direct one LNB output two two receivers. For a cost of about $25 he would get a 3/4 switch and solve his problem at the same time have surplus spca for additional two LNBs input and two more receivers output.
In the past you have made some unacceptable statements and again you are coming with lack of some basic knowledge.
4 x 1 diseqC = 4 LNBs to one receiver.
3/4 switch = 3 LNBs to 4 receivers.
GET IT???
Username: Nydas
Post Number: 16193
Sump:
3/4 multi-switch
http://www.centralsatellite.com/productview-521.html
"This Mult-Switch Splitter combines two LNBs and one off-air or cable into into 4 outputs. All unused ports of the VM3400 should be capped (terminated) using 75 Ohm Terminators. This will reduce "ghosting" , interference of off-air signals, weather damage and lockups."
4-1 DiseqC switch
http://www.inverto.tv/products/product.php?section=3&id=140
"This small and reliable 4 into 1 DiSEqC switch will enable the reception of signal from 4 satellites and their distribution to a single tuner Set-top box with only one cable entering the house."
Also please inform and educate Greg Ruffian, the Ecoustics clown.
Username: Sump
Post Number: 423
nalin ..
what is the model number of a 3x4 switch in question that you are RECOMMENDING this user to use and are saying i do not know what i am taking about !!!!!!!!!!!!!?
hint retard ..
http://transatelectronics.com/store/ecoda-3in-4out-multiswitch-1-sat-4-rec_P203
Username: Sump
Post Number: 424
if you have NO practical experience you actually MUST READ the F'in information and not just look at the pictures when you CUT and PASTE
Username: Sump
Post Number: 425
3x4 = 1 LNB to 4 recievers !!!
Username: Sump
Post Number: 426
ok i am done now ...
i had some bad personal news couple hours ago and i am upset, i paritailly took it out on you.
I apologize for the rudeness not the tech info.
i am out for few hours.
also i apologize to the forum
Username: Watch_dog
Post Number: 42
sump
You have him in the corner go for the KO.
Username: Watch_dog
Post Number: 43
said aozal
Username: By2006
Posted on Monday, September 28, 2009 - 08:07 pm:
said aozal to stop all this madness and help you, please tell us how you have it wired?
are you running one wire from your
LNB and connecting it to a splitter and from the splitter to each receiver or from one receiver to the other?
Username: By2006
one lnb to reciever1 , then from loop to reciever 2
Username: Watch_dog
Post Number: 45
OK,said aozal thanks,
do away with the loop to receiver 2
and run a wire from your LNB to your receiver 2 and watch TV.
Username: Gregraf
Post Number: 3529
Sump you are doing a great job in this forum . No need to apologize, Some people just don't have a clue. Nalin makes my blood pressure go to 260 over 140 whenever she speaks.
Username: Nydas
Post Number: 16196
Idiots:
The MOST standard practice in FTA world for viewing from two receivers is to have a multiswitch capable of powering at least two receivers.
The most frequent thing that people often do is to add another satellite because of certain need for extra channels.
Combine these two needs and you end up with a multi-switch capable of handling 3 sats and outputing to 4 receivers.
Joker: You never run two wires directly from one LNB to two receivers - you will get problems with both receivers.
Take your joking somewhere else.
Username: Nydas
Post Number: 16197
Grg Ruffian: Stop being a clown and get out of the pub and back home to your wife.
Username: Gregraf
Post Number: 3531
K nalin ive had to much i need a cab
Post Number: 1860
U all are speculating without any idea what LNB, switches or satellite/s he may want...so why ya arguing?...u all may be right to a point and maybe not also...
IF he only wants 1 satellite for 2 receivers, all he would need is 1 dual LNB (not twin LNB or ANY switches) and 2 cables, or use the loop out on the first receiver to 2nd (if he don't mind watching same channels concurrently)...BUT none of us knows what he has and really wants..so enuff said..
Ya all argue like a bunch of school girls..and none are impressive...nalin always has to complicate everything and mix the pot, she must have an orgazm everytime she posts....
Username: Nydas
Post Number: 16201
justforhaha's aka LK: Surely you know better than what you just said. Or is it because you hate me so much that you have to slyly disagree although you know very well that I have said the standard FTA truth?
Username: Watch_dog
Post Number: 48
You really are stupid
Username: Nydas
Post Number: 16203
Wow!!!
Greg Ruffian had an orgasum as soon as he saw Justforhaha's aka LK posting!!
Username: Nydas
Post Number: 16204
Joker: He has a single output LNB. You can't run two wires out from it.
HE DOES NOT HAVE A DUAL LNB.
Post Number: 1863
If wanting only 1 satellite, running 2 cables from 1 DUAL LNB to 2 receivers, works just fine...thats exactly what DUAL LNB's are made for.....case closed..
Username: Nydas
Post Number: 16205
He is better off with a multi switch then change the LNB for a DUAL.
QED
Post Number: 1865
NEVER in this thread does the person seeking help ,EVER state he has a SINGLE output LNB...he says NOTHING about what type LNB he is using!
nalin ...don't jump to conclusions..and presumptions..U continually mislead ppl with advice without knowing the FACTS!
BTW...no need for any switch if using a DUAL LNB ( 2 outputs) and only 1 satellite...
Username: Nydas
Post Number: 16206
justforhaha's: Read the question.
"hi , i have tow recievers , i connect both of them ,for tow rooms, the problem is if i turn the first one i loose signal on the secend one please help,"
"one lnb to reciever1 , then from loop to reciever 2"
You alsways have had problem with understanding the practical aspects and long term solutions in FTA world.
Tomorrow this guy will come and ask I am adding anothe dish for XYZ satellite, etc etc.
I gave him a simple $20 solution to use a 3/4 mulitswitch so all his current and anticipated future needs are catered for without disturbing the LNB already installed. He would be ready for up to 3 sat inputs and for two more receivers.
Next time you are thinking FTA look for simple solutions for the ordinary person. The days of tech savvy people coming to the forum are over. Simple easy to implement solution preferrably without breaking your neck climbing on roofs are what people are looking for.
Username: El_tora_the_great
Post Number: 109
u go girl
Username: Nydas
Post Number: 16207
Whiskey: justforhaha's is a male/female.
She is far more knowledgable then you are, so you just shut up.
Post Number: 110
You are a female too you sick old b1tch
Username: Nydas
Post Number: 16208
That's not what my wife thinks, you dumb old hommo
Username: Blade1
Post Number: 32
WHAT?!!!?? Whiskey is a transexual monkey?
Username: Watch_dog
Post Number: 49
said aozal said he had one LNB
he did not say if his Lnb was a single or a dual.
what kind of multi-switch to connect two receivers to one sat?
Are you talking about a splitter? If his Lnb is single
a Multi-switch would cost as much or more then a dual Lnb
and he would still have to run
another wire from the Multi-switch to the second receiver.
said aozal I do fill bad about all this
but do what ever is best for you
Username: Nydas
Post Number: 16211
Joker: sorry for you but it is more convenient to try a 3/4 mulit-switch inside the house. We know that it WILL do the job.
Username: Plymouth
Post Number: 11060
Sump
There are 2 kind of 3X4 Multiswitch
One with 3 LNB imput and one with 2 LNB imput and VHF/UHF TV antenna.
You don't need to insult Nalin, he is right on it!!!!!
The guy doesn't give any reply, so this is a good romantic thread where everyone give a answer without known what system he had.
Username: Plymouth
Post Number: 11061
said aozal
Look on your dish and check if you have a LNB with 2 outputs, if yes you must put a new wire and hook it on your second receiver.
The Loop output work only if you use both receiver on same channel.
Is it a Dish or Bev original dish?
Username: Nydas
Post Number: 16214
Thanks Plymouth.
Username: Plymouth
Post Number: 11062
Nalin
You are Welcome!
Sump need to be more respectable with helpers, we tolerate his publicity on Ecoustics because its helps, but he should not insult the members.
Post Number: 1866
justforhaha's
Post Number: 1860
Posted on Tuesday, September 29, 2009 - 08:27 pm: Edit Post
Plymouth
Username: Plymouth
Post Number: 11061
Posted on Tuesday, September 29, 2009 - 09:49 pm: Edit Post
Here we go ....Plymouth copying me again stating EXACTLY what I said earlier, just in different structure.....and then nalin, blasting me and commending Plymouth for saying the exact same thing...
nalin either U are very ignorant about English comprehension, or a bigo*t and hater towards me, an American...
Username: Plymouth
Post Number: 11063
haha's
I am the first to give a answer to this guy and I asked how many satellite he had.
You have reply without his answer, is it the same that you made?
A bunch of idiots made speculations without reply from said aozal
Take your pills
Username: Sump
Post Number: 427
NALIN AND PLYMOUTH
again and again and again
WHAT IS THE MODEL NUMBER OF THE 3/4 SWITCH THAT WILL DO WHAT
PLYMOUTH AND NALIN SUGGEST ..
SO WE CAN ALL LEARN,
IF YOU ARE SUCH GOOD HELPERS ANSWER THE SIMPLE QUESTION ...
Username: Plymouth
Post Number: 11064
sump
This one:
http://www.sadoun.com/Sat/Products/S/S-SM34-3x4-multi-switch.htm
Don't think that we are stupid with switch.
For only 2 receivers this is useless but for 3 or 4 this is the good choice.
Username: Plymouth
Post Number: 11065
sump
You can add 1 3X4 switch for each LNB and hook it on a Diseq for each receivers, which give you a possibility to made a big system with multiple LNB's and receivers.
Note that you always need LNB's with 2 outputs for more than 1 receivers system.
Username: Riconissan
Post Number: 1994
My turn....
said aozal already has a cable in the house. Why screw around at the dish? just put a switch in the house like Nalin has explained.
said aozal,
You came to the right place for your answers. Nalin and Plymouth are your best sources.
Sump is learning.
Gregraf hates anything Nalin has to say.
NC USA
Post Number: 107
Plymouth....sump...Don't think that we are stupid with switch.
No ,no one here thinks you two are stupid
what ever gave you that idea?
I think you two are fu-cking morans.
You two may know what a 3X4 switch is
when you look it up, but I will bet that you two
never install one.
Nalin Nyda
Username: Nydas
Post Number: 16211
Posted on Tuesday, September 29, 2009 - 09:35 pm:
DISH Network DP-34 VideoPath Dish Pro 3x4 Multi-Dish Switch (DP34) 107107 Works with Dish 300 and Dish 500 satellite systems. Can be used to cascade additional DP34 multiswitches for more receiver outputs. Can only be used with DishPro LNBFs.
Availability: In Stock Our Price: $74.99
Post Number: 1997
LMAO
Username: Tapeman
Post Number: 4428
There is only one Stupid Retard on this forum
That's yo aribian boi
This switch is a polarity stacker
It passes both V&H polarity on one coaxial if the LNB is dual to start
It converts 14v(V) and 18v(H) to one common stack of 20V(V&H)
Basically works only with Dish Net power supply and accessories
I see yo know nothing about it to compare it with a 3x4 Sw
TFR
Username: Nydas
Post Number: 16215
If you are using a FTA receiver, avoid using a DP34. Use the switch suggested by Plymouth.
If you have a Dishpro LNB and two Dish receiver, you should use a DP34.
All connections can be made inside of your house.
1. Disconnect the main cable coming from the roof and put it into Input 1 of your 3/4 multi-switch.
2. Disconnect the cable going from your receiver no 1 to receiver no. 2 and put it into output no 2 of your 3/4 multi-switch.
3. Connect a new short cable from output 1 of your 3/4 switch to the input of your receiver no 1.
You are all set to view two different channels on the two receivers.
Username: Nydas
Post Number: 16216
From a practical point of view, IT DOES NOT MATTER WHETHER THERE IS A DUAL OR A SINGLE LNB
The method I have described requires very little effort, no climbing on the roof, very little cost and a 100% chance of success for a novice.
Post Number: 1998
Username: Plymouth
Post Number: 11066
Whiskey
Go play with your Tonka!!!!
Username: Tapeman
Post Number: 4430
"From a practical point of view, IT DOES NOT MATTER WHETHER THERE IS A DUAL OR A SINGLE LNB"
Is that right Nalin?
How is that going to improve his polarity share issue?
Single LNB is a single Polarity V or H
But not both at same time since he's using loop out
In electronics we call it exclusive-OR or X-OR
I haven't seen any product out there that converts a single LNB to a dual
And I know yo know electronics
Unlike this 14 year old aribian boi who doesn't know sh!t about electronics
So therefore the only solution for original poster is:
- Replace LNB with a Dual LNB matching same freq
- Run 2 coaxial cables one to each receiver
- Case closed
Username: Sump
Post Number: 429
No NALIN and Plymouth ...
1) 3x4 switches are all the same that's why there called 3x4 and not 4x1 or 4x4
2) you MUST have a DUAL LNB to use it, one wire from the roof will NOT work on a 3x4 switch in the basement
3) IF he does if fact have one dual LNB running one wire from each port to each receiver will absolutely work fine
4) the most likely thing he probably has is a twin or 2 singles up there with a diseque on the roof and one wire coming down with the recievers tied together
so with that said someone needs to get to the dish, one new wire needs run from the sat to 2nd reciever,
based on #4 adding a 4x1 to the existing setup and running new wire to 2nd is the best solution and will allow for future expansion or
based on #3 running new wire to 2nd box is the best and will allow for future expansion
Username: Sump
Post Number: 430
sorry king missed the post we posting at same time .. but are saying same thing
good post KING
NC USA
Post Number: 114
Plymouth
Username: Plymouth
Post Number: 11066
Posted on Wednesday, September 30, 2009 - 10:16 am:
Whiskey
Plymouth
Forum Rules
DO NOT use profanity or demean your fellow users.
Username: Kingsatman
James MacPhuck, Middlesex co... Canada
Post Number: 466
Whiskey
On behalf of Plymouth please accept my apology
I think what he meant is GO FU.CK YORSELF
Stupid aribian Retard
NC USA
Post Number: 115
POST # 4
Whiskey
NC
Post Number: 101
Posted on Tuesday, September 29, 2009 - 07:30 am:
Post Number: 467
This is 12.2 to 12.7GHz for DTV yo stupid qweer
Works on Circular polarities
How do yo know if he's using Linear or Circular yo fu.cking H0M0?
NC USA
Post Number: 116
Yukon
Post Number: 466
Posted on Wednesday, September 30, 2009 - 10:47 am:
Whiskey
King Tapeman
Forum Rules
Username: Nydas
Post Number: 16221
A 3/4 switch is designed primarily for three inputs (2 LNB + Antenna or 3LNB) and outputs to four receivers. It does not mean that you have to populate all the inputs and use receivers on all the outputs
Therefore, whatever signal(s) are coming down to him can be distributed by a 3/4 multiswitch to four receivers.
If it is D/N LNBs then use DP34 and Dish receiver. If it is non-DN LNB coming down then use a 3/4 multiswitch.
To educate yourself, please read this sticky at
http://www.ftatalk.com/showthread.php?t=263435
Whether you have any of the four types of legacy LNBFs, or Standrd FTA dual LNB, or Dishpro LNB (3 types), you can use the appropriate 3/4 switch to go to two receivers.
NC USA
Post Number: 117
Yukon
Post Number: 467
Posted on Wednesday, September 30, 2009 - 10:59 am:
You Sir know nothing about this Hobby
More of this name calling and you will leave
me no choice but to report you to the Admin.
Username: Nydas
Post Number: 16223
Whiskey: Will you just get off this thread. Go and report to Admin, if you want to. We are all talking about DN, not DTV, so Yukon gave you a proper shove off. In your own language, you have "no choice but to report" Yukon "to the Admin".
So be a good boy, and do just that and wait in that thread for the next 3 days while we sort out the technical arguments here, OK?
Username: Sump
Post Number: 431
NO NALIN AND PLYMOUTH
again
you read it is supportting EXACTLY what myself and King are saying here is the relitive part
The 3x4 Multiswitch is one of the most common multiswitch used in FTA. Combines the 2
outputs from a standard dual LNB into the 2 inputs of the switch marked 13v(Vertical) and
18v(Horizontal) usually the 2 outer inputs on the top of the switch. The 3rd or middle input on
top of the switch is used for an input from an antenna or cable tv* . The outputs on the bottom
of the switch is to feed up to 4 receivers or feed other FTA switches. (These are pictured on the
left in the first and seconded pictures)
read this line again ...
Combines the 2
that is ONE DUAL LNB look at the pictures so you can educate yourself what means you need to hook BOTH sides up from the LNB to the 3/4 Switch so how the hell are you going to do that with ONE wire in the BASEMNET ??
RETARDS ...
YOU MUST GO ON THE ROOF !!!!
YOU MUST RUN 2ND WIRE FROM THE ROOF
IF IN FACT HE DOES HAVE A DUAL LNB AND YOU MUST RUN A WIRE FROM THE ROOF THERE IS NO NEED FOR 3/4 SWITCH !!
DOOHHH
Username: Sump
Post Number: 432
http://images.solidsignal.com//iview.asp?p=sam3402&xzoom=Large#xview
if you look at the little markings on the inputs it does NOT SAY LNB 1, LNB 2, like a 4x1 switch it is labeled that way for a reason not because they thought it would be cute !!
NC USA
Post Number: 119
sump give it up those two are too
stupid to understand what you are saying.
Username: Nydas
Post Number: 16227
Sump...King:
We agree to disagree. I see no point in continuing further. As the story goes about the Greek philosophers sitting round a table discussing and never agreeing on the number of teeth in a horse's motuh, and the farmer walks in with a horse and tells them - Open the mouth and count.
The way to resolve would be similar - do it and see the result.
Username: Tapeman
Post Number: 4431
"A 3/4 switch is designed primarily for three inputs (2 LNB + Antenna or 3LNB)"
Not 2 LNBs
Rather One LNB (1-for V Pol, 1-for H Pol), 1-for Antenna
This won't correct the problem he's having
When he watches H-Pol programs he can't watch V-Pol at same time on two receivers
3x4 switch is designed for One Dual LNB
1-designated for 14v Vert Pol
1-designated for 18 Horz Pol
1-for antenna
4-Outputs to 4 receivers
Yo can read this section:
https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1496579#POST1496579
I think yo assumed 2 inputs for 2 LNBs
But it's rather for 2 polarities of same LNB
This 3x4 basically splits one dual LNB to 4 different receivers
Peace Bro
Username: Plymouth
Post Number: 11072
http://sadoun.com/Sat/Installation/Multi-LNBF/4-receiver-4-lnbfs.htm
Username: Sump
Post Number: 435
Nalin and Plymouth ..
Sump...King:
that analogy is true because there was no INFORMATION, no one counted before and wrote it down
This has subject tons of info saying the same thing even your backup documentation. The trouble is you guys really do not understand the facts in front of you.
You could just be a MAN and admit that you's are wrong , like i have before here.
you guys do good with the NON technical stuff but become lost when it gets past a certain point.
So instead of us and them it can be we ..... that is the learning process
Username: Nydas
Post Number: 16231
QED
Username: Sump
Post Number: 436
Plymouth ...
NO again ...
Plymouth
Username: Plymouth
Post Number: 11072
Posted on Wednesday, September 30, 2009 - 12:33 pm: Edit Post
just another cut and paste that you have no idea what is going on in the little pictures .. some of us here do !!
This supports what we are saying .. Look at ONE LNB .. the first switch 2 wires to one switch then one out
YOU CANNOT USE THE 3x4 with ONE wire from the LNB !!!
it is the wrong switch for this application
DOOOHHH
Username: Sump
Post Number: 437
if all the old guys that were sitting at the table 8 in total ... counted the teeth, 7 said 18, one said 24,
what would one conclude ?
the one that counted 24 is RETARD and rode short bus to school and can't count ?
Username: Nydas
Post Number: 16232
QED
Username: Plymouth
Post Number: 11073
sump
I just want advertise you that I doesn't bashed you, so stop your bashing on me or you will see what will happen with you!!!
I will stop your publicity on this site, remember that you are a competitor to Ecoustics.
Right!
If you think that I don't understand what is in the picture , do few search on Ecoustics before pretend to know all.
Username: Sump
Post Number: 441
sir how did i bash you ?
Username: Plymouth
Post Number: 11074
""just another cut and paste that you have no idea what is going on in the little pictures .. some of us here do !!""
This one!!!
Username: Plymouth
Post Number: 11075
sump
I never say that you can use only one wire on a 3/4 switch, read a little.
Username: Sump
Post Number: 443
Plymouth says ....
Plymouth
Username: Plymouth
Post Number: 11064
Posted on Wednesday, September 30, 2009 - 07:44 am: Edit Post
sump
This one:
you are saying that the switch WOULD work knowing he has only one wire
YOU READ
Next .....you post
Plymouth
Username: Plymouth
Post Number: 11072
trying to say that it will work also the 3/4 switch ?
Knowing he has only one wire
SO YES U DID SAY IT WOULD WORK TWICE !!
Username: Plymouth
Post Number: 11076
sump
You are not able to found where I says that, I says that a 3/4 multiswitch can work but I never say that you can do it with only one cable, you misinterpreted my post, I says that with only 2 receivers you only hook 2 cables on a LNB with 2 outputs.
Stop your arguing and found where I says it!!!!
Username: Sump
Post Number: 444
that was your post ... C&P
the thread was about ONE WIRE so any reference to a device that needed 2 WIRES was USELESS !!! CONFUSING!! and NOT HELPFULL!!
you knew the man had only ONE wire .. so the fact that YOU said it would work or suggested that switch ....SAYS that you recommended it ... by the fact of your post !
why would you even post something you KNOW doesn't work if you understand the problem ?
Username: Tapeman
Post Number: 4437
"Btw don't trust King Tapeman he is also another Big Big fu-cking Rat."
Nope
Yo don't have to worry about that
Members here trust yor 50 usless posts over me
Username: Nydas
Post Number: 16233
Dishpro question only.
King, would you kindly let us know what would happen if only one sat e.g 119W was connected to this. Will two (or 3 or 4 receivers) work?
http://www.prosatellitesupply.com/dish_network_dp34_switch.htm
Combines 3 Orbital Locations to power 4 Receiver Outputs
Features
Three inputs to capture signals from three orbital locations (61.5°, 105°, 110°, or 119°).
'¢ Four outputs for connection to four single-tuner receivers. (Any combination of single and dual-tuner receivers can be connected however, dual-tuner receivers act as two separate receivers and require connection to two ports.)
'¢ Three "cascade" feeds to cascade to other DP34 switches. Up to three DP34 Switches can be connected in a cascade to feed up to 12 single-tuner receivers.
'¢ Switch is powered by receiver. Does not require AC/DC power insertion.
Username: Sump
Post Number: 446
Plymouth
Username: Plymouth
Post Number: 11065
Posted on Wednesday, September 30, 2009 - 07:52 am:
you posted this too
it is bull !!! BIG bull !! the whole post
if you have dual LNB you do not even need the 3x4 switch !!! DUH
just the disques ... so why did YOU RECOMMEND SWITCHES that are NOT NEEDED ?
and KNOWING that he has only ONE WIRE FROM ROOF
YOU READ !!!!
Username: Watch_dog
Post Number: 54
said aozal
Username: By2006
said aozal......Post Number: 1
I bet you all will not see post number 2
ecoustics should change this forum from Satellite TV to My Laughing Place
Btw .....said aozal thanks
Post Number: 1999
He probably went and got a cable sub.
Username: Plymouth
Post Number: 11077
Joker
Here is the answer from:
said aozal
Username: By2006
Posted on Tuesday, September 29, 2009 - 07:23 pm: Edit Post
Read before open you big mouth!!!!!
Sump
Here is my answer to said aozal:
Plymouth
Username: Plymouth
Post Number: 11061
said aozal
Where you see a problem?
On my first reply I made a little error when I writed:
"You can't use both receiver on same LNB"
I forget to write LNB output, but we don,t need to be much bright to read the complete post and understand what I'm saying
My first post:
""You can't use both receiver on same LNB, you must use LNB with 2 outputs.
List the satellites that you use and we can help you to make that it work. ""
I hope now that you will understand and stop your arguing!!!
Username: Tapeman
Post Number: 4438
"Dishpro question only.
King, would you kindly let us know what would happen if only one sat e.g 119W was connected to this. Will two (or 3 or 4 receivers) work?"
Well, this is an excellent question
From what gathered
- Each LNB on all D#N is a dual LNB to start with
- Internal circuit board that connects each LNB it does something called stack polarity
Meaning it takes both 14v, 18v polarity on a new stack polarity of 20V via one coaxial cable instead of 2, voltage is collected via DP34 or DP44
- They use a separator 123254 for dual tuners if they need to split it
D#N perfected this process to send in particular for DVRs in multiple rooms on one coaxial
Now keep in mind this separator works with DishPro LNBs only, DP34 or DP44, the separator when required
The new black HD receivers has built in separators for dual tuners
I hope this answers yor very good question
Username: Watch_dog
Post Number: 55
What about these two posts when Nalin
then you say to sump...You don't need to insult Nalin, he is right on it!!!!!
Nalin Nyda
Username: Nydas
Post Number: 16211
Plymouth
Username: Plymouth
Post Number: 11060
Posted on Tuesday, September 29, 2009 - 09:43 pm:
Sump
now let us see how the rat gets out of this trap.
I would say that you and Nalin should get
down on your knees
and apologize to Mr. sump
Username: Plymouth
Post Number: 11078
Joker
You are a idiot or you are not able to read!!!
Here is a 3X4 multiswitch with 3 LNB inputs:
http://sadoun.com/Sat/Products/JVI/35-DN34.htm
One 3X4 with 2 LNB inputs and VHF/UHF TV antenna:
http://sadoun.com/Sat/Products/S/S-SM34-3x4-multi-switch.htm
Take your pills and learn again!
Username: Sump
Post Number: 447
Yes Plymouth i accept your apology for being wrong ..
also from Nalin's link in the PDF file
"The DPP Separator is with with DPP LNBs & DPP switches only. A DPP Separator can placed
on a single RG6 cable to output to a dual tuner receiver. Most FTA receivers do not support the
separator so does not work with FTA systems.
The Sonicview 360elite PVR is the only FTA receiver that DPP Separators work with so far,
however as new models come out -- more will support the DPP Separator."
also you need 2 of these switches ..one on the roof and then another @ the reciever to unsplit the signal
this will not work for 2 separate receiver boxes IMHO
DP PLUS LNB's add a whole other level of discussion ...
the solution STILL puts you ON THE ROOF !!
POST # 3 in this thread was and is the answer until information was given from user
Username: Tapeman
Post Number: 4439
Nalin
Yo can check few specs on it here:
http://www.solidsignal.com/pview.asp?mc=02&p=123254&d=DISH-Network-Dish-Pro-Plus -DPP-Separator-(ES148534)&sku=
Username: Sump
Post Number: 448
PLYMOUTH you are the IDIOT
NO No no again .... C&P only
NO KNOWLEDGE to back it up !!!
this is not a 3x4 switch it is a DP 34 MULTI SWICTH
yea yea yea another typo !!!
it was 1 of the solutions i said in post #3
Username: Sump
Post Number: 449
king ..
this MUST have a DP Plus LNB to work
which i am sure you know ..
Username: Plymouth
Post Number: 11079
Sump c0ck socker!!!
Why you give this answer when you don't know which LNB the guy has. Poor idiot yourself!
A DP34 is a 3X4 multiswitch made for Dn
We can talk about C/P from you everytime on your ch1t site.
Look you in the mirror stupid sump!
Username: Gregraf
Post Number: 3535
Wow sump you have come a long way down the acoustics trail. I new you couldn't stay nice forever.
Username: Sump
Post Number: 450
joker ...
Username: Sump
Post Number: 451
Plymouth ...
you were bashing joker for exposing YOU !!
I know I know just another typo, or just idiot .....
a DP 34 is one of the solutions that i was refering to but at the time it was unnecessary to go into specifics that early into the discussion not knowing all the facts, figured to keep it short and simple.
You can dodge and run but cannot hide on this one ..
YOU MUST GET ON THE ROOF to solve this gentlemens problem you cannot do it in the basement with switches
See i have no problem saying i C&P
I cut and Paste ....
but most of the time i know what i am cutting and pasting and can explain it YOU SIR are clueless in this matter
YOU DO NOT !!
then again i can type my own stuff w/o C&P
Username: Plymouth
Post Number: 11081
Bla Bla Bla!!!!
Post Number: 2002
I guess it is you and me.
Username: Plymouth
Post Number: 11082
and the whinner is............Waste sump
Username: Sump
Post Number: 452
u guys crack me up !!!
Post Number: 2009
That Rico is huge! Thanks Esvaldo. You must have got the details from our chica in Columbia.
Post Number: 2010
POST #2
Plymouth
Username: Plymouth
Post Number: 11056
Posted on Tuesday, September 29, 2009 - 06:30 am:
said aozal
Username: Nydas
Post Number: 16234
We have already proved that my suggestion of a DP34 for Dishpro receiver will work. It is a simple matter of a DP34 with only one LNB attached to it. it will distribute the signal to 2-4 receivers. QED.
Next question to King please.
This guy said aozal has one cable coming to his receiver and he has all the channels on it. From that description what kind of LNB and setup he might have?
Username: Sump
Post Number: 458
yep makes all the sence in the world ...
hmmmm ..
used DP34 68$ cad plus shipping ..
well some RG6 cable and 2 ends PRICELESS !!
Username: Sump
Post Number: 460
hmmmm ..
USED DP34 68$ cad plus shipping ..
http://www.worldwidesatellites.com/catalog/product_info.php?cPath=23_62&products _id=204
Username: Plymouth
Post Number: 11092
sump
You are very loud now!
This is not the solution to hook 1 receiver to 1 Dual outputs LNB but it can work.
Read the total thread and see the majority says only to installed a new cable.
Username: Chumley
Post Number: 594
AZZHOLE PLAYMOUTH STFU
Username: Picanha
East LA
Post Number: 734
sump Playmouth and nalin get pizzed when someone has more knowledge then them. It's downhill from here. They run off all good help
Username: Plymouth
Post Number: 11094
Cumley
Go play with your toys
Chevez
You are the clown of the site, so your comments are like you.
Username: Sump
Post Number: 462
Plymouth ...
CAN YOU HERE ME >>> NOW ?
Username: Sump
Post Number: 463
Plymouth ...
CAN YOU HEAR ME >>> NOW ?
Username: Sump
Post Number: 464
plymouth this majority ??
but NOT you
SUMP SAID ....
Username: Tapeman
Post Number: 4440
"his guy said aozal has one cable coming to his receiver and he has all the channels on it. From that description what kind of LNB and setup he might have?"
That's what I was trying to find out myself
But I'm almost certain he's got 97W
Therefore Linear LNB
And this idiot Whiskey posts Aspen Circuilar LNB
I made that guess cuz the guy registered in 2006 and had only 2 posts so he either got IKS FTA or true FTA
I say he got 97W true FTA with Single Linear LNB
Username: Nydas
Post Number: 16238
King: Thanks for your deductive logic.
Username: White_girl
Post Number: 116
The Telephone man and his Crystal Ball
Username: Rtf
Post Number: 112
I wonder if said aozal ever got his receivers hooked up.
Username: Sump
Post Number: 471
RTF good one
King my crystal ball said that if he ever was in FTA that he would have had 2 LNB setup, 1 sat 2 LNB and disk 4x1 on the roof that's my bet
WONDER if this post can catch up with the
solo hispanics !!!
( edit corrected typo's )
NC USA
Post Number: 121
sump I think Plymouth is mad at you for making him look like a
Username: Tapeman
Post Number: 4441
Freedom of the Press and Whiskey
I feel bad for yo bro
Yo don't know sh!t about satellites dude
Yo pick on members that are far more superior in knowledge and education
Yor not even trying to learn bro
Yor IQ is far from adult standards
Yo can't even speak englic
So I'm not sure what on earth yo're doing on this forum?
Can yo please give us some logical explanation?
Username: Nydas
Post Number: 16240
King: There is a lot of people on this forum and some of them with duplicate triplicate accounts, who do not understand anything about debate or even discussion.
Username: Sump
Post Number: 504
MASTERdeBATERS
