KBOX video recording
Username: Xhounddog66
Hi,
When you record to a usb stick or an external hard drive, is the file ready to watch or does it have to be converted to avi etc? Does it work well? Is the quality good?How about the hard drive? Do you watch the recordings through the kbox receiver? I have the phoenix receiver but want a receiver that I can record from.
Thanks for your help!
Username: Sump
Post Number: 510
yes file is ready for playback on the Kbox not problem
But to view on something else you must convert the .ts file to different format .
quality is excellant .
kbox will also view your picture files too on the stick
there is glich using external usb drive , some reports of when setting the timer in advance ..
kbox is looking into it ..
