From Viewsat to Kbox
Username: Soccerlover
Hello,
I have 2 dishes (small ones) : one pointed on 61.5 for DN and second on 91.0 for BEV. Both were working with Viesat extreme until the bins working.
I bought recently a KBOX PRODIGY and I tried to get channels with no success.
I got some FTA channels (indicating that orientation is fine) but for the real channels I have no sound, no image.
Could someone help me to fix this problem ?
Should I change LNB, dishes or something else to use Kbox and get channels ?
Thank you in advance.
Username: Regrun2
Post Number: 62
from what i know, KBOX does not support 61.5 and 91 right now..
i also have kbox prodigy and dish pointed to 118.7 and it works fine.. but for 118.7, you need bigger dish and circular lnb..
you can still use your small dishes.. but point it to 110W, and that would work on kbox..
correct me if i m wrong here more senior guys :-)
hope this helps..
Username: Saqeeb9000
Post Number: 5862
u should be able to see some bev channels
for international u need 118.7 dish..
61.5 won't work
Username: Nydas
Post Number: 15940
Also please remember that to receive Anik F3 (118.7W), you NEED a 33 inch dish and a special LNB for it. The combination costs as little as $60 plus installation costs if any.
Username: Abe125
Cali
Post Number: 28
you will be glad you made the switch... dont be a fool standing around for a n3 bin... it just not going to happen anytime soon .....im still waiting for the p4 hack...
Thank you guys for your advices.
I have to look for new dishes and lnb now.
Once again thank you.
Username: Sjain80
Post Number: 158
can anyone tell me the website where I can buy kbox from..
Username: Sjain80
Post Number: 159
never mind..I got it..
Username: Sump
East coast USA
Post Number: 98
kboxsales.com ....
also many channels up on 91 kbox ...
Username: Sump
East coast USA
Post Number: 99
also must be connected to internet
