Philips 50PFP5332D/37 problem
Username: Leonardp92
Please look at picture, set has 7 verticle lines with some double imaging, the color is black and white. It was suggested that it needed to be updated with the latest firmware which I did but it did not help. I also was told it could be one of the logic buffer panels or the logic main panel but I'm not sure how to test/check these. Any suggestions or tips would help.
Thank you,
PLUpload
Username: Drkwlf
Laplace, Louisiana Usa
i have the same exact tv and same exact problem have u resolved it or figured it out or heard anything philips wont help me at all
It turns out it was the W2 Logic Main PCB. Set works like New!
Username: Drkwlf
Thanks appreciate the info
Username: Irisht57
Morgan, Pa Usa
If I buy the Phillips 50PF9630A 50" widescreen Plasma HDTV am I going to have to spend additional money to get a good picture?
