Bronze Member Username: Imran4811
Richmond hill,
Ny
AMERICA
Post Number: 67 Registered: Dec-07
Posted on i just got the new bin file i think its just fine, but am getting autoroll keys on the screen how can i turn autoroll key on and where exactly it is |
Silver Member Username: Chumley
Post Number: 350 Registered: Dec-08
Posted on It is located in cas menu menu , parental control , second pin - enter pin code and you will see it. also while on a channel enter 8282 - shortcut to cas menu the unit will find the new keys with autoroll turned off, too
Platinum Member Username: Nydas
Post Number: 15304 Registered: Jun-06
Posted on After you enter second Pin (usually 0-0-0-0), click on the last item. There you will see autoroll for BEV DN Globecast |
