Can someone explain the difference between these boxes. What channels are up? What do you need to make them work? What's easiest to set up and use? I'm pretty sure SV need an extra piece to use iks, an ihub i believe, do the other two?...Thanks in advance.
tj88 nfusion first iks reciever in business of fta reciever was built in with etherent port , no need to use hub, u can plug ur network cable directly in to nfusion, status: 80% channel up on bev (excluding ppv,po*rn) pros: first of kind , first box was in market was up was during ecms , first to released nagra 3 channels on bev with iks.. no dn internationals yet, cons.. pvr sucks, pic qualit not impressive , nostandalone bins
k1plus: box was released few years ago, took lot of time for it to make "iks stable".. almost 3-4 months,uses khub that goes from back to ur rec
pros: built in pvr, option of standalone/iks pic qualit is impressive cons: no bev channels yet,
sonicview. old in business but new with iks. so u don't know how well the will do with iks , again its not that easy...different models available, so far bev and dn channels up ,with freezing reported no premium channels yet.
