Becky: The current use of your receiver is through a PUFF_LZMA conversion a the LZMA BIN version 217. However, the nedd to convert or the level of current conversion if any, can only be stated after you look at
MENU/SYSTEM INFO.
Post what you see exactly as it is and we can then proceed to the ultimate goal of LZMA_217.
joeturn : I have alerted you several times that you DO NOT have the the expertise in most of the areas your are posting in. Yet you keep on interfering and misleading people, who are looking for help, AND UNDERMINING the efforts of many who are tryin to help.
ONE YEAR AGO, i.e. in May 2008, ther were the following alternatives which could be on a Pansat 2500.
1. Original Pansat factory BIN. 2. Pansat 2500 Bins by BL - last one being 294 3. Pansat 2500 Clonesafe Bin - last one being 294t. 4. Pansat 2500 to 2500 conversion B75 BIN by Black Tyger - version 269 or earlier 5. Pansat 2500 to 2500 conversion B75 BIN by Tronic - version 269 , a direct conversion. 6. Pansat 2500 to 2500 conversion Puff BIN by version 269 by the following authors: Fwank7 jvvh, Nick mty Saif UKR Haddad Lothario 7. Pansat 2500 to 2500 conversion Puff BIN by version 269 by Tronics - a direct conversion.
8. Pansat 2500 to 2500 conversion Puff-LZMA BIN by version 260 by Lothario, Black Tyger, etc.
Each one of the above group needs a different set of instructions and with your interference YOU WILL RUIN her chances of getting an appropriate conversion of BIN.
Look at this garbage. Has anyone here found any of his posts useful? I can't find one.
Ex: "After they realized the repair funtion in ie5.5 was giving the edge to conciel down loads and spy ware.They immediantly sent out ie 6 to oliminate this function!
xp and upwards take full adsvantage of IPv6 this was reccomended by the music industry so media center could keep track of cd pirates! This also works against sat piracy!!"
