Silver Member Username: JoeturnPost Number: 345 Registered: Apr-06 | I know they did it especially for me!! I did not have to rescan this time all my channels were still there! Now thats got me to wondering why is it they dont want me to blind scan?? Sorry guys I slept through tudors but it will be back through out the weak maybe on sho-w<I;-) |
Gold Member Username: PlymouthCanada Post Number: 9076 Registered: Jan-08 | joeturn What are you talking about? |
Gold Member Username: Tigger_woodsNOBAMA, NOBAMA Post Number: 1137 Registered: Jun-07 | Say it aint so Joe |
Gold Member Username: DoreenakadjOntario Canada Post Number: 2834 Registered: Dec-06 | LMAO |
Bronze Member Username: Peeps365Post Number: 44 Registered: Feb-09 | This!!!! is a half forum 1/2 blog site ppl use this site to say any thing, what they cat eat last nigt what tricks they cat can do especially this forum |
Silver Member Username: JoeturnPost Number: 347 Registered: Apr-06 | Well the curiosity got the best of me and I deleted all channels!! The new files were not kind this time as they threw my usuals way out of coodinates and the verticals would not load on 8/10!! After a few hours I I managed to whip this tiger by using 1.2 settings for all except 9/13. The next hurdle will be to make the files rename my local channels! This is no biggie as I only need two channels sho-w and sho-e.. I had to change quite a few settings this time as who ever scanned the sats had all that junk and a stationary dish with dip switches out the yang yang and a viewsat recieveer!! Interesting how much info you get from a download!! Was I right on the viewsat it was a guess but we know it was not a pansat nor sonicview<I;-) Jump on that for me pie master !Time is a waisting<I;-) |
Silver Member Username: JoeturnPost Number: 349 Registered: Apr-06 | I see the patch on ones coat says "NCEST is BEST" and another says "The closer the kin, the deeper in"..What does this mean grass-hopper?? |
Silver Member Username: JoeturnPost Number: 350 Registered: Apr-06 | This thread was posted in reference to this thread plymouth https://www.ecoustics.com/electronics/forum/home-video/567167.html |
Gold Member Username: PlymouthCanada Post Number: 9085 Registered: Jan-08 | joeturn I'm not able to understand all what you says but on Viewsat, if you don't want to lose your channels do it: Do a factory default, load the factory bin from viewsatusa.com and the satellite info then the latest bin, now scan all your satellites. Don't take old factory file available from many sites. If you experiment freezing, slow channels change or display who seems flashing, you only reload the latest bin and the receiver do a hard reboot by itself. Why reload the latest bin, because you will lose all your channels or experiment a night rider(----) and your receiver can record few data errors which give you a less performance receiver. |
Silver Member Username: JoeturnPost Number: 352 Registered: Apr-06 | I tried that and still cant rename my local channels the new file carries with it the scanners stored lat lon which does not match mine. So to re-enter my specifics wont allow my usualls to work properly. Blacksmith would have took such privy out of a file before he listed it! This is why he quit sending pre-scanned files for pansat. There were too many questions about how to select the correct set-up as each users were different!! |
Gold Member Username: PlymouthCanada Post Number: 9086 Registered: Jan-08 | ""I tried that and still cant rename my local channels the new file carries with it the scanners stored lat lon which does not match mine."" What is lat lon? joe can you speak a ENGLISH which I can understand? |
Silver Member Username: RiconissanPost Number: 774 Registered: Feb-09 | joeturn, Sort by SID and select your local? What bin are you talking about. You should be able to rename any channel. Nothing is misspelled above. |
Gold Member Username: PlymouthCanada Post Number: 9087 Registered: Jan-08 | Rico What is lat lon? |
Silver Member Username: RiconissanPost Number: 776 Registered: Feb-09 | Latitude and longitude coordinates. Makes no sense the context of his post. |
Silver Member Username: RiconissanPost Number: 777 Registered: Feb-09 | I suspect joeturn Listen to Parliament and smoke what they do! LOL |
Silver Member Username: RiconissanPost Number: 778 Registered: Feb-09 | See |
Gold Member Username: PlymouthCanada Post Number: 9088 Registered: Jan-08 | LOL Joeturn must smoke for sure. |
Silver Member Username: RiconissanPost Number: 780 Registered: Feb-09 | You know we like you joeturn. Just pulling your chain. |
