Expert Help Needed
Username: Jagsa
Post Number: 32
I have a Pansat3500sd. I have just loaded BIN315T and everything just washed out. I reloaded the previous file 315 and then 315T.
The problem is: I am trying to get Echo8.1 which was running nicely. Then the dish moved its position due to the high velocity winds in the area. Since then the Signal level is 51 to 61% but the signal quality remains 0%. In the same position last week the level and quality were 87 and 91% . The signal level varies between 50 to 63% but quality remains 0% I have tried repositioning the dish but no improvement.
Do we need something additional to attach to the dish, since there was a rumour that after April 17 the signal would change to digital or something
Kindly help as I am not getting any channel at all.
I haven't been able to access Future-Fta.info since the past week, i am aware of the server being down but this long makes me feel I am missing some vital info.
Thanks for the help in advance
Username: Zagros
Post Number: 260
jags; try to do a factury defult, load the factury bin, reload the bind 315T. It might help.
