Hi Nalin...I have a DN500 with a couple lnbs on it...I wanted to test on Bell 91 and 82...I am located in Southern NJ...can I use the dn500 to get bell 91 and 82? I know they are n3...I might have an nfusion box soon... Will the dn500 be strong enough or do I need something larger? any help would be appreciated...Thank you.
DN dish, DN LNBs, even the combo 110/119 LNB are all compatible with scanning Bell. Note that the special DN LNB 110/119 has a 9 degree separation, same as Bell's 82/91. As long as you are pointing in the correct direction, and have your Nfusion properly initialised, you are OK. Use the same DisEqC settings, that currently exist for the DN channels. All the best.
