My 2500a says P U F F over and over
Username: Machedonul
Post Number: 431
I have tried several bins, several conversions, i dunno what i did to be honest with you b/c i tried several tutorials. Now i'm at the point that it just says P U F F (last step I did was load 209 puff lzma bin)...how do i reset everything so i can start from fresh?
Post Number: 432
anyone?? :-)
Username: Satopia
Post Number: 364
yeah you need to load this to get it out of the puff puff over and over then start over do the puff conversion then do the 1.03 conversion
so load this first to fix your puff issue
http://www.sendspace.com/file/9tbm4q
then use this to convert it http://www.sendspace.com/file/sv72nm
Username: Satopia
Post Number: 365
migth even want to load old puff conversion first then do the 1.03 conversion
Post Number: 433
Vann, THANK YOU so much for your help b/c now im at the point that it doesnt say PUFF ocer and over and like it used to. I did a blind scan and i see that all the channels are SCRAMBLED OR BAD CHANNEL. does bin 209 work or is it outdated? and how should I have the A/R keys be, all ON?
thanks again!!!
Username: Satopia
Post Number: 366
ok on 209 theres a auto rool issue so you need to add key maunally or wait 30 minutes for it to roll
Post Number: 435
should it say SCRAMBLED OR BAD CHANNEL or does 209 actually work?
Username: Satopia
Post Number: 367
dss-key.com to get current keys
Username: Satopia
Post Number: 368
and make sure to use the new puff conversion bins for your box the Fwank7_Jvvh-Team-PUFF_(Lzma)_V209 bin
