SV4000 - Need Help
Username: Mhiqbal
My SonicV4000 was O.K last night, today morning it stuck and shows boot on SV screen for long time and does not come-up. I tried disconnect power plug of the box for long time turned it on still stuck on "BOOT". Anybody help will be highly appreciated.......
Username: Plymouth
Post Number: 7366
Dish Dish
Load the factory bin from:
http://www.sonicviewusa.com/
I don't know sonicview but usualy you power off with back panel switch then you press and hold the power button on front receiver then power on on back switch and release the front button, now you load the factory with the cable and loader then you load the latest bin.
Username: Mhiqbal
Plymouth,
So many thanks for your reply and help. I did load the factory bin " SV4000_1[1].58_factory" got from above SV site. Did not load the latest bin. BUT STILL HAVING SAME PROBLEM "BOX STUCK ON " BOOT".
Am I missing anything?
Username: Mhiqbal
Plymouth, Nalin, LK, Sada
Anybody please help..........
Username: Plymouth
Post Number: 7367
Dish dish
Try it for the HD8000, but i'm sure that is the same as for your receiver.
---------------------------------------------How C/P from another site.
To Fix Stuck On Booting For Sv-hd8000
Stuck with "booting" display recovery procedure
Here is the steps to revive your receiver if it gets "stuck on booting" where the display stays on booting and doesn't complete and reboot.
1. Do a clean FAT32 format on your USB stick.
2. Load the latest update bin file to the USB stick.
3. Turn the rear power switch on the receiver OFF.
4. Plug your USB stick into the receivers USB port.
5. Now do a forced load by pressing the MENU key on the front panel of the receiver and at the same time switch the rear power switch ON. Continue to hold the MENU button until you see "LOAD USB" on the front panel then release Menu button. It will then boot from the USB stick.
IMPORTANT NOTE: When using this step, please make sure there are nothing else in the device besides the latest bin file (That is the reason behind the clean FAT32 reformat)
Username: Mhiqbal
Plymouth,
Tried as you wrote. Still not working....
Anyway, thanks for your efforts and help.
may be I need to buy new one.
Username: Plymouth
Post Number: 7370
Dish Dish
Sonicview seems to have many problem with "stuck on boot" and it seems that it doesn't have solution for recover the receiver.
On Viewsat Ultra I force the bin with the Loader for VS Pro. You can try to load it as it: with switch on back panel power on and send the file before complete boot and try it with different delay and many time.
Good luck
Username: Nydas
Post Number: 14299
See if you can use this
[link removed]
SV4000_SysCleanFile
Hello All,
Here is SV4000_SysCleanFile to clean out the old code, please follow the instruction properly to clean out old code.
This is not necessary for those who's not being affected by glitch/bug.
Instruction:
1. Factory Reset (using Menu-Installation)
2. Format USB device (make sure it USB 2.0 compatible)
3. Extract SV4000_SysCleanFile.zip to a folder
4. Copy file SV4000_SysCleanFile.bin onto the USB device
5. Insert USB device into the STB USB port and start the flash update
6 Once the update completed, you can flash with the latest update and do dish setting/sat scan.
NOTE:
- Do a hard reboot (power OFF-ON using rear switch) after every update.
Ciao
SaCoDi
File Type: zip SV4000_SysCleanFile.zip (1.12 MB)
