Bronze Member Username: Hockeycraze12000Post Number: 38 Registered: Nov-08 | What sats do i need to get all the hd channels on Dish network? I am currently pointed at 110 and 61.5, do i need any more sats? |
Gold Member Username: PlymouthCanada Post Number: 7133 Registered: Jan-08 | Khalid Alakoozi With dish 1000plus: (110,118.7,119,129) Dish Network TurboHD DISH 1000.4: (61.5A°W, 72.7A°W, and 77A°W) Dish Network DISH 1000.2: (110,119,129) hd channels are on 61.5W, 72.7W, 77W, 118.7W and 129W |
Gold Member Username: JustforhahasPost Number: 1694 Registered: Jul-08 | Most are on 129W satellite Go here to see whats on which satellite for Dishnet... www.dishuser.com |
Platinum Member Username: NydasPost Number: 14082 Registered: Jun-06 | You should get the Eastern Arc setup (61.5W, 72.7W, 77W), and/or get DP 1000+, which gives 110W, 118.7W, 119W, 129w.
Please remember that most of the HD channels are Nagra 3 encoded and are no accessible from FTA receivers. |
Bronze Member Username: Hockeycraze12000Post Number: 39 Registered: Nov-08 | ok, let me it put another way what hd channels will i NOT get if im pointed to 61.5 and 110.0, thanks for the help |
Gold Member Username: DimwittPost Number: 1068 Registered: Aug-06 | It seems you would be missing about 8 ppv, CSNCA & Altitude look here www.dishuser.com/hdchan.php |
