118.7?
Username: Raceman24_1999
Post Number: 19
i have dish 500 pro dish head can i get 118.7 with it?i cannot find it on my satellite list....i have sonicview 1000.
Username: Nydas
Post Number: 13804
Plus Dish 500+/1000+
Same as the Dish 1000 in function but about 5" larger and can pick up the 118.75W FSS location.
As a 500+ it picks up 110W, 118.75W and 119W. Adding an LNB for 129W makes it a 1000+.
DP 1000+ LNBF ASSEMBLY
The DP 1000+ Assembly consists of the DP 500+ LNBF Assembly, the 1000+ bracket, ad a separate DP Dual (or DP single) for 129A°.
Post Number: 20
ok but i ask if i can get it with dish 500
Username: Nydas
Post Number: 13810
You can't get it with a Dish less than 33". 30" of 500+ suffices with the special LNB from DN. If you use other LNB such as CB2008A or Digiwave DGL1189s you will need 33" dish.
Username: Jay_w_grayson
Prague, Oklahoma USA
Post Number: 274
roy mercer.....ok but i ask if i can get it with dish 500----NO
