Pansat 3500S
Username: Canguy21
First of all wanted to wish all our friends a very happy holiday season and all the very best for 2009
My Pansat 3500S does not show any transponders I am using the 307 file. Is it because Dish has moved to nagra 3 or is it my receiver.
Nalin has always been helpful in the past, but if anyone else can give me an answer it would be most appreciated. thanks
Username: Chumley
Its not because of nag3.
Where is it not showing transponders, in antenna setup?
If after a blind scan it shows no TP's, try doing a satellite scan instead
Username: Nydas
Post Number: 13679
I suggest a full factory reset, load a factory bin to clear out any memory corruption issues (if any), load latest bin, re set all your settings and take NOTHING for granted in setup settings, check ALL SETTINGS and recheck.
DO NOT USE a channel list saved prior to the Full EMU BINs. (i.e the ones starting at 301)
Username: Canguy21
Nalin and Chumley: I want to thank both of you for your advise, I followed Nalin's advise and loaded the factory Bin along with all he asked and then I followed Chumleys advise and did a Satellite scan and it worked- so thanks folks and a very happy new year to you and your families
