Can some one tell me that new 202 tronic is working fine or not if not then is there anyother option
Username: Kaanwal
Ont Canada
Post Number: 27
Can some one tell me that new 202 tronic is working fine or if not then is there anyother option.
Username: Juancho
CANADA Xx
Post Number: 346
the other option is fwanky7, but you have to rescan the chanals after load the bin,
both bins are the same.
they erase your setting, you write your settings before load the bin, ,
Username: Kaanwal
Ont Canada
Post Number: 28
I download the tronic 202,is working fine.
Username: Jkmago
Post Number: 246
working fine Tronics 202
Loading Bin Tronics 202
When loading is complete Switch off the box from back as soon as you see P and do not wait for channel # to appear on box.
Loaded Tronics about 6 hours ago and it is working fine with no problem and also did not do factory reset before loading all channel were there. No need to do rescanning.
Cheers!
Username: Perycles2005
Post Number: 78
Can you post the link for the tronics bin...thanks
Username: Plymouth
Post Number: 6473
Perycles2005
Check on this site free no login
http://currentbins.com/ftafiles/
Username: Jkmago
Post Number: 248
Here is the Link for Tronics and Fwank PUFF File
http://www.ftabins.net/forumdisplay.php?f=122
Username: Juancho
CANADA Xx
Post Number: 350
I don't like, have that ways, everytime that you turn off the receivers or it turn off by
himselef everythings is lost,
I am talking about tronics bin, I will try Fwanky now,
I do this just for know about
puff bins
Username: Mkvl1490
Post Number: 162
I'm using franky bin, and IT KEEP FREEZING
Its getting annoying right now. Whats the problem
Username: Juancho
CANADA Xx
Post Number: 351
then use tronics bin but after rescan ch. don't turn off the receiver
Username: Mkvl1490
Post Number: 163
Ok, I had to wait
But I turned off autoroll, and set default key
Not working
Username: Juancho
CANADA Xx
Post Number: 355
makaveli, after the ch, comes on, you have tu turn off(back switch) after the reboot ,will show ON, then press OK for the epg to load, and do not turn off the receiver again because
everything will be gone,
Username: Mkvl1490
Post Number: 164
Ok, look at the edit above you
Username: Mkvl1490
Post Number: 165
Working fine, thanks
