just wanted to give you a word of thanks nalin.after much reading of your posts i have finally got my 2700 back to life.i sure hope it gets easier from here!again,thanks
i would like to say thanks also but i still have a probelm i put the 124 then the v201 then done a blind scan on 7 ku then 8 ku i dont have all the channels and what i do have i have 4 of each any ideas thanks in advance
The v201 BIN is different kind of BIN. You have to treat your receiver as a totally new receiver after installing it - that mean that you do a user setup and antenna setup and a rescan like setting up a new receiver. You have to post your LNB and switch type and something about your Dishes, and Antenna setup before anybody can help.
idid factory reset so after factory bin so just choose language option was up then loaded the v201 , then chose english, then blind scan and i got everything back full list and a few i was missing.
