French channel TV5 and Leonardo TV
Username: Tocolo
Toronto, Ontario Canada
Whatever happened to TV5 and Leonardo TV.
I have DN.
How can I have them again? For a while, they worked, and now they are scrambled.
Username: Tooter
Post Number: 92
If you are talking anik f3 (188.w)
lyngsat and http://dishuser.org/dishlist.php -show-
TV5 tp 11745
LEO WORLD TP 12124
Try scanning those transponders
Username: Plymouth
Post Number: 6013
Bric a brac
You must have the special LNB and 30" dish or dish 1000 for get those channels.
Username: Bouttep
Post Number: 95
i have a dual lnb and a channel master 6 foot antenna can i get them
Username: Plymouth
Post Number: 6017
joe damas
Yes if you use a circular LNB on it.
Username: Bouttep
Post Number: 96
how would i know if it's circular
Username: Plymouth
Post Number: 6018
Joe
Check the model on LNB.
Usually it is a C-Band which is use on 6' dish.
Is it motorized?
Username: Bouttep
Post Number: 97
no it's not motorized , i have 2 of them one 110 and one 119
Username: Cartier1
Post Number: 2222
JOE U CAN NOT USE THAT DISH FOR 118. YOU NEED BIGER DISH 33'
Username: Tocolo
I said I have dishnetwork. The sats are I think echo 3 and 7 ( 61,5 and 119). And I always had a small dish.
I think they moved the channels around, but i don't know where.
Username: Cartier1
Post Number: 2224
BRIC TV5 is no longer in echo3 they moved it to anik f3 118w . u have to use big dish for that with circular lnb
Username: Tocolo
Please Cartier1 can you explain more in detail?
Does that mean, that I have to add another dish? A big one? How big? What do you mean by a circular lnb?
Thanks.
Username: Tooter
Post Number: 98
C / P
YOU MUST HAVE
1. A 30-33" DISH.
2. A SPECIAL LNB FOR 118,
CB2008A OR DIGIWAVE DGL1189s.
What you could do is aim the existing 119 dish to 110w and put up new dish to get 118 and 119 -
the above lnb's will get both 119 & 118
Username: Jay_w_grayson
Prague, Oklahoma USA
Post Number: 123
joe damas........... i have a dual lnb and a channel master 6 foot antenna can i get them
cartier1........ JOE U CAN NOT USE THAT DISH FOR 118. YOU NEED BIGER DISH 33'
Username: Cartier1
Post Number: 2228
FTA I DID NOT MEAN JOE, I MEANT BRIC. SO GO HAVE A LIFE AND GET A JOB AND STOP GETTING FOOD STAMPS.
Post Number: 126
cartier1
Don't be piss at me I can't read your mind if you have one.
I only post what I see. Because I try to correct you
there is no need for you to break bad.
a) Thank GOD I do enjoy the good Life
b) I have a good job
c) The only stamps I get are postal stamps.
Username: Tocolo
Thank you guys for your help. Appreciate.
1 more question though. What kind of programs an channels does Anick fr3 carry ? I mean beside TV5. And why in the world, they are doing the transfer?
Thank you.
