Missing PPV in DN 110
Username: Pizza
Post Number: 109
Hi
I have only two DN 110 PPV channels how can i get other PPV
I scanned specific frequency too
Username: Mrgreg
Ont. Canada
Post Number: 87
Rescan complete echo 10,11
Username: Mzakcat
Post Number: 84
must i rename or 8.6/8.10
Username: Lroy
Post Number: 444
You don't have to.
Username: Mzakcat
Post Number: 85
ok i believe my issue is now fine tuning problem, channel mastered some different ones and went back to my original and still no signal on just the ppv transponders:
12297,12326,12443 and few others yet i get great quality and sig on 12224 12661 anything and everything 110 nonppv?????????
Username: Plymouth
Post Number: 5633
Zak
Try to set your LNB Type on Standard if you use a generic LNB or OCS-DP if you use a DP LNB.
Which receiver?
Username: Mzakcat
Post Number: 86
2700a i got it on standard i believe its my old dtv dish and 119 is on the dish w/three lnb oval, its a little dark so im just gonna stick w 502 505 and 509 tonite.but if you think i can change stb settings w/out adjusting the dish i'll try it.
Username: Plymouth
Post Number: 5635
Try it zak and reply with the result
Username: Plymouth
Post Number: 5636
Zak
Check if your channels are all Vertical or horizontal or both?
Username: Mzakcat
Post Number: 88
on the tps that work the change between dishpro and standard doesn't change much but on like 12297 standard has level no quality and the change to dp kills level down to 30%
so adj dish in the morning?????
Username: Justforhahas
Post Number: 1196
LMAO @ plymouth's poor bogus advice...he will kill your receiver, be careful!
Username: Mzakcat
Post Number: 89
119 are both my bevs were both strangely all my 110 that work are v and the tps i want are h hows that work???
Username: Plymouth
Post Number: 5639
Check all tip on cable, put Vaseline on connectors for prevent moisture and hook it .
Username: Mzakcat
Post Number: 90
vaseline gonna fix my horizontal or is that just for the ch480-499
Username: The_coders
Post Number: 1426
Quote by zak michael:"must i rename or 8.6/8.10"
Viewsat you do , rename to 10,11 and rescan
Username: Plymouth
Post Number: 5642
Switch the LNB Type on 110, if it not work check all cable fron LNB and switch.
Bad cable give low voltage and you lost all Horizontal channels.
Polarization
Vertical(Right) 11.5 volts to 14 volts
Horizontal(Left) 15.5 volts to 18 volts
Username: Plymouth
Post Number: 5643
Vaseline is grease, use it on connector for protect against moisture.LOL
Username: Mzakcat
Post Number: 91
i'll try that next
but i really think i'm gonna have to realign check all cable tips and such in the morn. what does jfhh's think
Post Number: 1201
"my old dtv dish and 119 is on the dish w/three lnb oval"
zak...I would forget about that using that dish...
You need to realign that dish, and its NOT easy....and forget getting the 119, unless you add another LNB...if ya think ya have the 119, then I believe you are mistaken..and forget any Bev sats now, due to nagra 3...
I suggest you get a simple Dish 500 with either 2 dual LNB's, or a Dish Pro twin LNB..$45
[link removed]
Here what U have zak!....its not a good dish for FTA now..can only get the 110 now, unless u add more lnb's..
The Phase III oval dish (FAQ)
All about the Phase 3 dish
(made for DTV, has 3 LNBs in same enclosure and built in multiswitch.)
YES, you CAN use this for your FTA setup to get 91 and 110 !
Advantages
1. You can add 2 LNBs and get 82 and 119 too on same dish.
2. Cheap or free from your DTV system.
3. Use only one wire and get 2 sats.
4. If u add 82 and 119, you'll use 3 ports on your diseq switch.. perfect to hook up an additonal bigger dish and a linear LNB and get birds like Intelsat 5 (T5) on your diseq empty port.
Connection
1. You need only 1 coax cable per receiver connected to the Phaze 3 dish, which is an advantage.
2. It doesnt matter which of the 4 ports you connect to. All 4 are the same in functionality. Your receiver will use the built in multiswitch to select one of the 3 sats. It does that via voltage change and 22khz tone signalling.
What this dish is for and how it was meant to work
1. This dish is for DirectTV. Was made to get the 101, 110 and 119 DTV sats.
2. Looking from behind the dish, the LNB are used like so:
.......left lnb = 119 sat
..middle lnb = 110 sat
.....right lnb = 101 sat
3. The multiswitch inside uses 22khz tone that is sent by your receiver to switch between 2 sats (just like any other 22khz switch). You'll have to set that up in your Pansat receiver.
4. 2 sats?? Yes! The multiswitch inside also serves as a combiner to combine signal from 110 and 119. So the 22khz will switch between the signal of 110 and 119 combined and the signal of 101
How the built in combiner works
1. The combiner takes TPs 2, 4, 6, 8, 10, 12, 14, 28, 30 and 32 from the middle LNB (110) and all the rest of the 32 TPs of the left LNB (119). You cannot change what TPs are combined... Covering middle LNB with foil wont work, cutting traces on the pcb wont work.
2. This is OK for DTV because DTV only has 3 TP's on DTV's 110 (28, 30 and 32) and they are different from the TPs on DTV's 119. (a tp is a frequency band on which up to 14 channels are transmitted). So combining different frequencies on the same wire, works fine. But it will affect your FTA setup.
How the built in combiner affects your pansat setup
1. You can use the Phaze 3 dish to get the 91 (bev) and the 110 (dn) satellites.
2. For that you point the dish to 101 (middle lnb), and adjust the skew. Now the left LNB picks up 110 (looking from behind the dish) and the right LNB picks up 91.
3. The combiner will combine TPs 2,4,6,8,10,12 and 14 from the 101 DTV sat with the rest of the TPs of the 110 DN sat. This means you will not be able to get TPs 2,4,6,8,10,12 and 14 from the 110 sat. but read on to see what your're missing.
What channels will i be missing on my Pansat
1. You will be missing only some local channels. (ABC,CBS..etc..), which may or may not be local to you. Thats it !
2. To see what is missing you go to lyngsat and check to see whats on TP 2,4,6,8,10,12 and 14 on DN's 110 sat.
4. You will see that ALL but 2 of these TPs are of BEAM type... which means you wouldnt have been able to get them ANYWAYS, Unless you are in the area indicated for that particular beam.
5. The 2 conus (available nationwide) tps that you'll be missing are TP 12 and TP 14. Whats on it? Only locals from Lexington, Knoxville, Jackson and Denver.
What you should be pointing it to, to get 91 and 110
FTA setup:
Assuming you will point this dish to 101 (middle LNB to 101), you will be able to get 91 and 110 on the 2 outside LNBs WITH proper SKEW, and thats what u want do to if you gonna use it with your Pansat. The middle LNB is useless for Pansat setups on Phase 3 dish as it will be pointed to DTV's 101 sat. Also covering this lnb with anything won't help to give u back those locals that you'll be missing.
To get the azimuth and elevation for your dish, calculate it for the 101 sat. For skew see below.
DTV setup
If you set the dish like above, it will not work for DTV. If you want it to work for DTV you point it to 110 (middle lnb gets 110) and the outer will get 101 and 119.
To get the azimuth and elevation for your dish, calculate it for the 110 sat. For skew see below. Or you can use your DTV receiver, enter your zip code and it will give you all settings.
U can't use the Phase 3 dish for DTV and FTA at the same time because you're pointing to different sats.
How to calculate and use Skew:
Skew= vertical offset (twist) in degrees from the vertical (from the 90 degrees mark on your dish)
1. Go to Satellite Nut page
2. Enter your location info.
3. Calculate skew for the 2 outter satellites on your dish (for the FTA setup on Phaze3 that would be 91 and 119)
4. Add them toghether and divide by 2
5. U get the skew number. (Disregard the minus sign if its negative)
To use SKEW:
You must ensure that the top of the mast is perfectly plum. Best thing is to use an eye round level (home depot,tools section - $3) that u put right on top of the mast. You do that BEFORE you even put the dish on the mast.
If you are on the EAST coast, skew = counter-clockwise rotation in degrees from the 90 deg mark on your phaze 3 dish. Set your dish to 90 minus the skew number
If you are on the WEST coast, skew = clockwise rotation in degrees from the 90 deg mark on your phaze 3 dish. Set dish to 90 plus the skew number
Receiver setup
No diseq switch is needed, only one wire needs to be connected to the Phase 3
91: 22khz OFF, Diseq - OFF (or ON - doesnt matter)
110: 22khz ON, Diseq - OFF (or ON - doesnt matter)
Can I also get 119 on this dish?
Yes, if you have an additional DTV or DN (circular) LNB laying around, you can strap it to the LEFT of the 3 existing LNBs (looking from behind the dish). You will now have to use a DiseqC switch to switch between the wire from the Phaze 3 and the wire from the strapped LNB.
Receiver setup with the strapped on 119 LNB
Assuming u put the wire from the Phaze 3 in port #1 and the wire from the strapped LNB in port #2, your setup will be:
91: 22 khz OFF, Diseq #1
110: 22khz ON, Diseq #1
119: 22khz OFF (or ON - doesnt matter), Diseq #2
Can I also get 82 on this dish?
Yes, if you have an additional DTV or DN (circular) LNB laying around, you can strap it to the RIGHT of the 3 existing LNBs (looking from behind the dish). You will now have to use a DiseqC switch to switch between the wire from the Phaze 3 and the wire from the strapped LNB.
Receiver setup with the strapped on 82 LNB
Assuming u put the wire from the Phaze 3 in port #1 and the wire from the strapped LNB in port #3, your setup will be:
82: 22khz OFF (or ON - doesnt matter), Diseq #
Username: Nydas
Post Number: 13061
zak: You said in an earlier post "....old dtv dish and 119..."
To get DN on that LNB is a definite NO-NO.
Use a simple 20" oval dish and a simple 110/119 LNB or two standard LNBs
Username: Nydas
Post Number: 13062
By the way, - the dish part of your DTV dish will probably work fine as a reflector if you just use the proper LNB for getting DN.
Username: Mzakcat
Post Number: 92
well that explains why i thought i was just getting a lucky bounce and getting bev on same line with turning 22k off on one or the other so then i'm actually hitting 110 on the oval, and my older dish is the 119
and i'm still not getting the horizontals but was busy today, now its dark again
but i will adjust tomorrow. ??
Username: Mzakcat
Post Number: 93
91: 22 khz OFF, Diseq #2
110: 22khz ON, Diseq #2
119: 22khz OFF (or ON - doesnt matter), Diseq #3 is what i got but thats because it sees em that way i think my Diseq was wired wrong inside. also for 91 i had to use echo 3 for scan cause nimiq scan used to shut box off, but when bev was up and i used echopackage my guide and channels were all together and worked great, a really great set-up or really retarded your choice,but i was happy, but now with bev down i want to get my missing tps back. ?
Post Number: 1244
zak...maybe U don't understand...U can ONLY get the 110 with that dish now, the way it is!
Username: Mzakcat
Post Number: 94
i understand that part but should i just ditch th oval and strap two on the round.
Post Number: 1247
[link removed] 9+with+DishPro+Plus+Twin+%28Used%29+LNBF.html
Username: Mzakcat
Post Number: 95
i still have other dishs/lnbs and many parts to test with outside of buying the dp twin, just looking for best idea for now. I still have hope for future bev couple months maybe but i also had hope and still keep the old h/hu/p4 crap around for someday
Post Number: 1249
Then use an old 18 inch round 1 LNB DTV dish and strap on, and epoxy 1 more LNB to get the 110 and 119...a poorman's dish...
Username: Mzakcat
Post Number: 96
i think i found one of those metal bracket poor mans in the garage and if the round is already hitting 119 than it should be an easy swap in the morning, but the metal has a angle kind of built in is that right or is it for hitting 110 first.?
Username: Nydas
Post Number: 13137
Strapping two LNBs is an idea about 5 years old when LNBs were costly ad people were using makeshift techniques.
Get a proper bracket and mount two LNBs or use a LNB meant to scan 110/119 on one.
Username: Mzakcat
Post Number: 97
i have the proper bracket the question was 110 or 119 like the picture, it has the extra one on the same side as the picture but it holds it angled closer to the dish not as straight as pictured.
Username: Plymouth
Post Number: 5703
Zak
Haha aka Lk is from florida, from his location he can play with a hose clamp, what he don't understand is that:
if you use a dish not made for 2 LNB you will lost signal because the focus on dish is in the center, try to get 119 first and 110 will be easy to get.
Username: Mzakcat
Post Number: 104
what i did and it worked,i took the three lnb apart pulled out the phase3 multi-switch ran cable direct to lnb and bang all horizontals fixed and 99% quality,
if bev ever makes a comeback i'll either replace multi or just run seperate line to other lnb. I can't believe it was that simple. thanx for the phase3 info, it saved me alot of uneeded repointing.
Username: Nydas
Post Number: 13212
zak: That was good work. I certainly did not know that you can made the DTV dish work that way.
You will be of great help on this forum.
Do not get distracted by the likes of justforhaha's. They are C/P artists who do not know what they are talking about.
Again I must emphasize that you did a great job and have certainly increase my knowlwedge
