March 5, 2008 New ECM by DN and BEV on March 4 ALL BINs CAN OVERWRITE EACH OTHER. You will be installing the 254 version, Jvvh_254_Nkk.bin or jvvh_254.bim A. THESE INSTRUCTIONS APPLY TO:
Pasnsat 2500A and named and nameless clones of 2500A Forect LifetimeUltra (If using an original pansat 2500a or clone or ultra, install 293T or 294T Bin first) Any of above whether converted or not converted. These instructions may be used for a new conversion or for upgrading existing conversions
B. Sites for download of files. All files that you may require are included in this package. Older and other files are available at: [link removed] [link removed] [link removed]
C. Preparation: 1. WRITE DOWN YOUR CURRENT TV SETTINGS AND ANTENNA SETTINGS. 2. Make a directory or subdirectory called "jvvh" 3. Unzip full_kit.zip into this directory. 4. In the Needed directory, you should have BL Updater 1.4, 225,280 bytes, jvvh_208_2500to2700.bin, 640KB Jvvh_254_Nkk.bin jvvh_254.bim 5. Straight RS232 DB9 F/F cable. 6. Receiver should be switched off. 7. Connect computer to receiver via serial port using 9 pin F/F DB9 cable above. 8. optional: (may be needed) {b75_m_1.bin, 64KB, jv_205.1.bin, 640KB, jvvh_208.1.bin, 458,752 bytes jvvh_218.bin } 9. Note that you do not need the full jtag files.
D. Action: Go into Windows explorer and find the jvvh directory. Go to Needed directory.. Double click on BL Updater 1.4 1. Methods of installation. There are two methods of burning (installing) these files. They only differ in when to start writing. In Method one, you click on Write at the same time as turning on th ereceiver. In method 2, you turn on receiver, and as soon as receiver shows "b", you click on Write. Method 1: Files that are boot files or contain boot file may be installed with switching on of the receiver and clicking on "Write" at the same time. These files are: jvvh_208_2500to2700.bin, 640KB (Select "BIN" in updater) Preferred jv_205.1.bin, 640KB (Select "BIN" in updater) Good alternative b75_m_1.bin, 64KB (Select "BOOT" in updater) Use only if above two do not install the BOOT Method 2: Files that are pure BIN upgrades are preferably installed after turning on receiver and clicking on "Write" when "b" shows up on the receiver. These files are jvvh_211 onwards to the latest BIN or CS_218T_lightning onwards to the latest BIN file In either method, after clicking on "Write" you must Wait whilst the receiver is showing a anticlockwise rectangle and later the receiver will show b75 flashing and the Computer will show "BURN". The receiver will reboot and show b-7-5 and then stop for a while on 5. Do NOT turn off receiver at this time. When the receiver is showing "ON", then only the process is complete and you can turn off the receiver. Most failures occur because of not WAITING. 2. Exact Procedure of installation. a. Install Boot conversion. Skip this part if the receiver is already converted and showing b-7-5 when it is turned on. If the receiver has never been converted, make sure it has the clone BIN 293T or 294T in it. Install jvvh_208_2500to2700 using Method 1. If this fails, install jv_205.1.bin using Method 1. If this also fails, install b75_m_1.bin, using Method 1. Make sure you select "BOOT" in the updater. b. Install latest BIN. If the receiver has been converted before or has just been converted as in a. above, install latest BIN using Method 2. Use Jvvh_254_Nkk.bin or jvvh_254.bim E. Connection to TV: 1. With receiver switch in off position, connect the Sat antenna, and the cables to TV. Turn on TV Turn on receiver. You will see b75 go across and freeze on "5". WAIT After a little while the TV will come on asking you to confirm Language English. Press OK.
2. First do Menu/ default settings (Factory default) It will ask for PIN -- use 1668 if you have forgotten your PIN, usually a 0000.
3. Next do User setup. The date/time will show as 01/01/2006 12.00 noon. Set time to manual and enter the correct time, date, and time zone. Make sure summer time is off. Make sure closed caption is turned off.
4. Next do Menu/Dish Setup/Antenna setup Select your known dishes and use the known DisEqC port connections. You can connect to ports without knowing which is which using trial and error and the signal strength.
Now do Blind scan (power scan) for each of the selected sats. You must see both Horizontal and Vertical TPs.
F. Watching TV: By the time you finish the blind scan, the new keys will have loaded and you are ready to watch TV. You MUST switch off at the back once and switch on. You can se up the channels alphabetically or in other ways using Channel Edit and Sort. You can and should set up P-lock on some P0RNO channels. You can rename the 5 Favorites using right arrow key. If a channel does not appear, you can do a separate TP scan. Also look for it in the list, e.g. channels 614 -- SET may appear in the list as TV 614, and you can rename.
HAPPY VIEWING If resets occur, try turning autoroll off and Closed Captions off.
INSTALLING PUFF BOOT AND BIN These instructions are for Pansat2500/FLU whether converted to b75 boot or not DO NOT USE ON GENUINE PANSAT 2700 OR REAL CLONE PANSAT 2700
Preparation 1. Connect receiver to compute rusing a straight RS232 cable 2. Turn on racier and let it come to rest at ON or the last channel number 3. Save your current channel list. 4. If your channel list is more than 6 months old, skip all the above. 5. KEEP RECEIVER ON. Loading Boot60 6. Start 2700 to 2500 conversion software by Chancysand. 7. Select Boot in the Loader software. 8. Select Boot60 from the distributed software. 9. With the receiver ON, click on Write. 10. Wait for write to complete. 11. KEEP RECEIVER ON. 12. You will see horizontal night riders. DO NOT PANIC. 13. Close the 2700 to 2500 conversion loader and Loading Boot/BIN PUFF -- must use the 640K PUFF BOOT/BIN combo. 14. Start the BL 1.4 updater. 15. Select Chancy's or jvvh 253 boot/Bin 640K file. The file name must have the word PUFF in it. 16. With receiver ON, Select BIN in the Loader and start write BIN. 17. When it has loaded it will say BURN on the loader software . 18. DO NOT SWITCH OFF. 19. When BURN is completed, your receiver will reboot and sat P-U-F-F 20. Leave it on. 21. Wait till it stops PUFFing and says ON. 22. Now switch it off. Loading latest PUFF BIN. This is the part to be repeated in future with newer PUFF BINs. You will always use PUFF BINs clearly labeled PUFF 23. In the BL update 1.4, select the latest 254 PUFF BIN and select BIN in the loader. Keep right hand on mouse ready to write. 24. Turn on receiver at the back using left hand and as soon as you see P (of PUFF) scrolling, click on Write with right hand. 25. Again wait for BURN to take place and then the receiver will reboot, go through the P-U-F-F cycle and rest with ON showing. Loading Channels. 26. Now install the channels using channel master. 27. Disconnect from receiver and connect to your TV. Do user set up and attend to autoroll. 28. First thing -- do a user setup including date.time, time zone and turn closed caption off. Blind Scan if Channel list old or not available. 29. If your channel list is good, you may skip a blind scan, otherwise do a Blind scan of your sat -- just one sat first. 30. If keys do not autoroll, go into parental control (CAS menu) and click on "Set Default key and wait for autoroll to load the keys. It takes about 2-3 minutes. 31. You must do switch Off and On at the back in between if things are not happening as they should..
Intructions on how to convert your Fortec STAR Lifetime Ultra to a Pansat 2700 CLONE.
First, here's a list of tools that you need:
- RS 232 female-female STRAIGHT CABLE - Fortec STAR Lifetime Ultra remote control
Instructions/Procedure:
- Please turn OFF your receiver and disconnect it from the satellite & the TV cable - Connect your receiver to your computer using RS 232 female-female STRAIGHT CABLE serial cable - Turn ON your receiver and wait 20 seconds - Open the FortecSTARSTB loader and select the boot file (b75_m.bin) - On the loader's screen, under the Type options, please select Boot - Now, please select the correct computer port (COM 1 or COM 2) - Make sure your receiver is still ON and connected to your computer - Now, on the loader's screen, please click Download - Now, wait for it to complete - After it's completed, you'll see B 7 5 flashing on your receiver's front panel/screen - Now, please close the loader's window and leave your receiver turned ON - Now, it's time to load the actual flash bin file into your receiver - Please re-open the FortecSTARSTB loader and select the flash bin file (jvvh_208_1.bin) - On the loader's screen, under the Type options, please select Flash - Now, please select the correct computer port (COM 1 or COM 2) - Make sure your receiver is still ON and connected to your computer - Now, on the loader's screen, please click Download - Now, wait for it to complete - After it's completed, you'll see B 7 5 flashing on your receiver's front panel/screen - That flashing B 7 5 will stop and freeze on number 5 for 30 seconds - After 30 seconds or so, your receiver will automatically boot (It'll turn ON automatically, after 30 seconds) - Now, please turn your receiver OFF and disconnect it from your computer - Finally, please connect the satellite and the TV cable to your receiver - That's It, you're done! Now, you have a Pansat 2700 Clone receiver
Note: After you finish with the above steps, you have to re-scan your satellite(s). After you're done with that, you have to enter the latest keys (Dishnetwork or BellExpressVu). Here's what you need to do after you re-scan your satellite(s):
- Go to MENU - Then, go to Parental Control - Then, go to Second Pin and enter 0000 - Then, go to Set Default Key - Then, go to Nagravision 2 to enter the latest Dishnetwork or BellExpressVu keys
After you enter and store the latest keys, please EXIT the menu and start watching TV!
CInthia guillen: Much of the above is my original instructions several months ago. The latest versions of the files and of the instructions are in the URLs I gave yesterday and again below.
[link removed] Download and unzip into separate directory. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
