Bronze Member Username: Fahadriz8Post Number: 98 Registered: Aug-06 | I was using puff, i have 2 sats connected . one at 61.5 and the other at 119. im using hte switch. all the settings were the same and stuff but all of a sudden the 119 has no signal. i tried factory default. new file. same problem |
Gold Member Username: PlymouthCanada Post Number: 4561 Registered: Jan-08 | Vince delete all channels and do a blind scan |
Silver Member Username: Albino_midgetPost Number: 679 Registered: Jul-06 | plymouth, is that your STANDARD ANSWER |
Gold Member Username: PlymouthCanada Post Number: 4562 Registered: Jan-08 | No it is the solution Right |
Silver Member Username: DimwittPost Number: 941 Registered: Aug-06 | i guess we'll have to see; becase the poster is vince carter bsaketball pro . and not jjgee ,rat fink |
Gold Member Username: PlymouthCanada Post Number: 4565 Registered: Jan-08 | Toto Give him the solution crazyer |
Bronze Member Username: Fahadriz8Post Number: 99 Registered: Aug-06 | i did, it says the signal for 119 is 29% with no quality. the satellite could have moved im guessing but the signal should still be higher then that? |
Silver Member Username: SatopiaPost Number: 251 Registered: Feb-08 | dunno why but mines doing the same with cw600s i just get singal is weak and thing about it is it was just working not even hr 1/2 ago now thats all i get and when i rescan i get 0 notta |
Bronze Member Username: Fahadriz8Post Number: 100 Registered: Aug-06 | ye mine was working fine like the strength of the quality was good and all of a sudden i started getting no signal |
Gold Member Username: PlymouthCanada Post Number: 4568 Registered: Jan-08 | Vince try my solution All is up on 119 without autorolling |
Silver Member Username: Fahadriz8Post Number: 101 Registered: Aug-06 | nope tried that |
Silver Member Username: Fahadriz8Post Number: 102 Registered: Aug-06 | Plymouth i did a factory reset and tried scanning, the 61.5 channels show up but the 119 has low signal and no quality, and when i do a blind scan, there arent any TP's found |
Gold Member Username: PlymouthCanada Post Number: 4570 Registered: Jan-08 | Vince which receiver? |
Platinum Member Username: NydasPost Number: 12220 Registered: Jun-06 | Vince - In the Antenna setup, are you connecting to DiseqC 1.0. That is the correct one and not 1.1 |
Silver Member Username: Fahadriz8Post Number: 103 Registered: Aug-06 | yep its 1 for 119 and 3 for 61.5 |
Platinum Member Username: NydasPost Number: 12233 Registered: Jun-06 | You must have for 119W: 1.0 - #1 for 61.5W: 1.0 - #3 |
Platinum Member Username: NydasPost Number: 12234 Registered: Jun-06 | You must have for 119W: 1.0 - #1 for 61.5W: 1.0 - #3 |
Silver Member Username: Fahadriz8Post Number: 105 Registered: Aug-06 | yep thats what i got, still i only get 61.5 and nothing on 119. any other ideas? |
Gold Member Username: PlymouthCanada Post Number: 4598 Registered: Jan-08 | Vince Do a autoscan with a old bin file then load latest file It work on Viewsat and Captiveworks. |
Silver Member Username: SatopiaPost Number: 252 Registered: Feb-08 | confirmed it works there bud great info all channels bk good deal |
Gold Member Username: PlymouthCanada Post Number: 4602 Registered: Jan-08 | alton vann penny Explain me "bk" please |
Silver Member Username: SatopiaPost Number: 253 Registered: Feb-08 | lol mean back bro sorry just alittle yahoo chat lingo |
Gold Member Username: PlymouthCanada Post Number: 4607 Registered: Jan-08 | Alton Ok all work now Thank for the reply my friend |
Silver Member Username: Fahadriz8Post Number: 106 Registered: Aug-06 | guys i installed an old bin and scanned and same problem. im using hte puff |
Gold Member Username: PlymouthCanada Post Number: 4632 Registered: Jan-08 | Vince Have you tried the LNB directly on Receiver without switch? I know the puff have freeze problem on Pansat On old bin you must do a blind scan(power scan), load latest bin then autoscan. |
Silver Member Username: Fahadriz8Post Number: 109 Registered: Aug-06 | ye i tried it directly too. the signal is 29%. and i also tried an old bin and did blind scan but for 119 it doesnt show any TP's. im thinking i boot it again with the boot60 and install the new file? what do u think? |
Gold Member Username: PlymouthCanada Post Number: 4639 Registered: Jan-08 | Vince Do it exactly in this order load old files, delete all channels, do a blind scan then do a autoscan, repeat it for each satellites and load latest file. |
Bronze Member Username: Fakeman1Germantown, Maryland USA Post Number: 58 Registered: Jul-08 | Ply(ofthe)mouth enjoys all this, being a rat and bashing all these people here becauce he knows no one here can touch him. I will bet in real life he is a little lonely old man. |
Gold Member Username: PlymouthCanada Post Number: 4640 Registered: Jan-08 | Kingsville aka jjgee the shemale, exit of this thread idiot. Grosse tapette |
Silver Member Username: Fahadriz8Post Number: 110 Registered: Aug-06 | nope didnt work plymouth i loaded 288 and did a blind scan still no TPS found. what should i do? |
Gold Member Username: PlymouthCanada Post Number: 4657 Registered: Jan-08 | Vince If you have older file this is best(june file) Before try to set LNB Freq on 10550 for 61.5W and scan whit it. |
Silver Member Username: Fahadriz8Post Number: 111 Registered: Aug-06 | can u suggest a file number? and some detailed steps |
New member Username: Nyd_usPOST: 12273 Post Number: 2 Registered: Oct-08 | Vince why don't u f@ck off you sh!t bag. Go somewhere else for help. |
Gold Member Username: PlymouthCanada Post Number: 4661 Registered: Jan-08 | False Nalin Post number 2 |
Gold Member Username: PlymouthCanada Post Number: 4662 Registered: Jan-08 | Vince Sorry i forget that 119 is in trouble,then don't try it ""Before try to set LNB Freq on 10550 for 61.5W and scan whit it." Give me your setting for 119 |
Silver Member Username: Fahadriz8Post Number: 112 Registered: Aug-06 | Plymouth now both of my satellites are showing no signal. my settings for both of them are, LNB Type:Standard LNB Frequency:11250 22 KhZ: Off Diseqc: 3 and 1 (switch) Legacy SW:None Skew: -45 Positioner Setting: Disable |
Silver Member Username: Fahadriz8Post Number: 113 Registered: Aug-06 | Plymouth, This morning i was playing around with the stuff and when i connect 61.5 directly and run a blind scan the channels start coming, but when i do the same for 119 its still no signal. Maybe my settings are messed or the lnb is troubled, or it could be the switch? what do u think? |
Gold Member Username: PlymouthCanada Post Number: 4677 Registered: Jan-08 | Vince Latest bin give us many problem with our receiver. It is like the LNB Tp display a number and this number is not the true number inside the box. Connect the 119W LNB directly on receiver then try different LNB Tp Frequency. It is very hard for me to recover it without the receiver in my hand. I am able to correct it with my 2 receiver Vs an CW. One thing is sure, the solution for recover all channels is very different for each user. Which receiver model? |
Silver Member Username: Fahadriz8Post Number: 114 Registered: Aug-06 | pansat 2500 clone, i think my lnb is faulty. i ahve this http://www.columbiabasinsatellite.com/KIT-500TWIN.gif |
Gold Member Username: PlymouthCanada Post Number: 4681 Registered: Jan-08 | Vince are you set on OCS-DP? Try 22Khz to on. |
Platinum Member Username: NydasPost Number: 12279 Registered: Jun-06 | Vince: This is just a general informative post. When disEqC switches get damaged or shorted, all ports are only Port 1. To avoid this situation, always have receiver power off when connecting/disconnecting. There is a latest 294 version of the puff file available. The old 2500/FLU receivers are great workhorses and you can easily revert to 2500 and start all over again. Make sure you install the old 294T BIN after installing BOOT 60 and then go on to Puff conversion and install the current PUFF_294 BIN. Dish LNBs are to be installed as OCS-DP and others are used as Standard. |
Silver Member Username: Fahadriz8Post Number: 115 Registered: Aug-06 | Nalin Nyda: I tried that with no luck. and to test the switch i plugged in 61.5 in all ports and it was working fine so im pretty sure my switch isnt the problem. |
Silver Member Username: Fahadriz8Post Number: 116 Registered: Aug-06 | Plymouth what is OCS-DP? and i will try 22 kHz on ON. |
Gold Member Username: PlymouthCanada Post Number: 4687 Registered: Jan-08 | OCS-DP is Dishnet LNB on Viewsat |
Silver Member Username: Fahadriz8Post Number: 117 Registered: Aug-06 | i tired the 22 kHz to ON, but it doesnt help. |
Gold Member Username: PlymouthCanada Post Number: 4699 Registered: Jan-08 | Have you tried to select a different LNB Freq, the good one is 11250, you can try 10550. |
Silver Member Username: Fahadriz8Post Number: 118 Registered: Aug-06 | ye tried that too nothing happens |
Gold Member Username: PlymouthCanada Post Number: 4705 Registered: Jan-08 | Vince Here is the best solution i found for recover channels and Tp, try it exactly in this order: Do a factory default, load an older bin, blind scan, load new bin and now you will recover all missing channels. |
Gold Member Username: PlymouthCanada Post Number: 4707 Registered: Jan-08 | Vince If it not work, try a new LNB |
Silver Member Username: Fahadriz8Post Number: 119 Registered: Aug-06 | ye im pretty sure the LNB is the problem. thanks guys |
Gold Member Username: PlymouthCanada Post Number: 4752 Registered: Jan-08 | You are Welcome |
New member Username: Bodie1Post Number: 8 Registered: Feb-08 | hello, I am having the exact same problem as vinceis having with my 2500flu on 119--no signal. Today I did the whole reload boot and latest bin and it did the exact same thing--want to hear the best part of this I have another one of these recievers and it so far is working fine.(knock wood)I thought maybe the thing was shot;but obviously not since others are having the same problem. Kay |
Silver Member Username: Fahadriz8Post Number: 120 Registered: Aug-06 | Kay so are u getting good signal for 119 on another reciever thru the same satellite? |
Gold Member Username: PlymouthCanada Post Number: 4777 Registered: Jan-08 | Guys I dont have this receiver for test it. Is it possible to try another file from another source? |
Platinum Member Username: NydasPost Number: 12301 Registered: Jun-06 | kay: Just check the names of the installed BINs and the antenna setting, etc. With identical receiver (converted) and identical BINs, you should be able to get everything identical. |
Silver Member Username: CarburantePost Number: 146 Registered: Jan-08 | hey Nalin i have been having troubles getting a 2500 puff on track(BEV).I loaded the bins (287 to 294) with no luck. i only get the msg 0 program found after all types of scans. i have also tried the autoroll off and put the keys manually (channel master's list)but same results. no autoroll and 0 channels any sugestion is appreciated!! |
Platinum Member Username: NydasPost Number: 12308 Registered: Jun-06 | GC is not working on Pansats, Viewsats, etc. For converted Receivers, PUFF_294 is working flawlessly on DN and on BEV 91W. I am told that it is not working well on BEV 82W. |
