Bronze Member Username: MeishaPost Number: 50 Registered: Aug-05 | Hi Guys Anyone help me out here, I am trying to set up my Dual receiver to have 2 cables so i can have the both tuner running at the same time. I do not want to do the loop back method. so here goes, I have a single tuner in my bedroom connected to EMP 4x1 DiSEqC Switches to dual LNB. What do i need to get my Dual turner receiver working on both turner without looping ? |
Gold Member Username: PlymouthCanada Post Number: 4782 Registered: Jan-08 | Meisha How many receivers? How many LNBs? |
Bronze Member Username: MeishaPost Number: 52 Registered: Aug-05 | I have 2 receivers and 3 Dual LNBs |
Gold Member Username: PlymouthCanada Post Number: 4784 Registered: Jan-08 | Meisha You can use two DP-34 too and 3diseq switchs |
Platinum Member Username: NydasPost Number: 12310 Registered: Jun-06 | You can also put splitters at of the LNB outputs before the cable goes to DisEqC switches to get 3 DisEqC switches working for three receivers. The splitters could be amplified splitters if necessary. You will need three splitters and one additional DisEqC switch. |
Silver Member Username: TherepoFtaview.com Post Number: 201 Registered: May-07 | If DishPro LNBs: One cable from each LNB to DP multiswitch like DP34. Then simply 1 cable from switch to each tuner (2 cables to the dual tuner, one to the other receiver, in other words). If Legacy/DTV LNBs: use voltage control muliswitches (2x4 or 3x4) and 4x1 diseqcs as in Plymouth's diagram. I'm not sure what Nalin means by "splitter", but you definitely don't want to use a cable-tv type splitter. |
Platinum Member Username: NydasPost Number: 12332 Registered: Jun-06 | Two neightbours integrated their dishes (2 each - total 4 dual LNBs) and channels four satellites into each home using diseqc. Then one person wanted another receiver in the basement. This was achieved by using 4 splitters at LNB outputs of the 4 LNBs so that instead of 2 DisEqC switches there are now 3 DisEqC and all three receivers are working independently and satisfactorily. One was not initially and some kind of signal amplifier was used to correct the problem NEAR the LNB output. I do not climb on roofs to look at wiring and other devices. However the above configuration is in place and working. I suppose if all the users were active at the same time and trigger happy, there would be freeze ups during channel changes, but in most normal viewing this is not the case. |
Bronze Member Username: Diaper_headPost Number: 24 Registered: Sep-08 | Nalin Nyda I do not climb on roofs Usually old girls can't. |
Silver Member Username: JustforhahasPost Number: 571 Registered: Jul-08 | she needs to define "splitter"..cause a cable splitter don't work.. |
Silver Member Username: JustforhahasPost Number: 572 Registered: Jul-08 | splitter is a cable TV terminilogyt...seperator and switches are used with LNB's and FTA |
Silver Member Username: PulpfiktionPost Number: 367 Registered: Mar-08 | hey justforhaha. Who dyu think U R....just a pimp on Florida waterfront. Haha. Haha Haha. Haha Haha. Haha Haha. Haha Haha. Haha Haha. Haha |
Platinum Member Username: NydasPost Number: 12334 Registered: Jun-06 | justforhaha - psycho. Everybody in this forum is not as stupid as you are. Obviously you do not use a fruit spitter for splitting signals and there are different types of splitters for different uses. You should use a splitter close to LNB and it should have a low signal loss and must have bidirectional pass through. Go to eBay or many other satellite sources and you will see appropriate splitter for the job in hand and some come with built in ampliflication. |
Gold Member Username: PlymouthCanada Post Number: 4815 Registered: Jan-08 | Again Hahaha come here make trouble in a thread. Disappear old tart |
Silver Member Username: TherepoFtaview.com Post Number: 202 Registered: May-07 | For the original poster: From someone who does climb around on roofs, you shouldn't get anything called a "splitter" nor should you use an amplifier. Again, a multiswitch is necessary to get more than 2 outputs to receivers from dual LNBs. The appropriate ones per LNB types I mentioned above. |
Platinum Member Username: NydasPost Number: 12336 Registered: Jun-06 | therapo, it is me , Nalin who does not climb on roofs. I don't know what Meisha's abilities are. Besides I do not know if he has a flat roof or a low slope roof. In Canada we mostly have 4:1 roof slopes - that's why I don't climb |
Silver Member Username: JustforhahasPost Number: 577 Registered: Jul-08 | nalin...again, you missed the point...the point is...don't use a "splitter", as you keep wrongly repeating to do!...I believe both myself and therapo cannot make that any clearer.. |
Gold Member Username: PlymouthCanada Post Number: 4816 Registered: Jan-08 | therepo Meisha has never reply on this thread, then we dont know all his system. For Hahaha idiot, if you don't know a splitter for satellite signal, don't post anymore here. http://www.sadoun.com/Sat/Order/Switches/Splitters.htm |
Silver Member Username: JustforhahasPost Number: 579 Registered: Jul-08 | you linked..Those are CATV ( cable TV) intended switches...or to split a IF signal from 1 TV to another TV...not for pre LNB use.. |
Platinum Member Username: NydasPost Number: 12338 Registered: Jun-06 | Go and update your knowledge, old woman. Can't you read? ustforhaha - psycho. Everybody in this forum is not as stupid as you are. Obviously you do not use a fruit spitter for splitting signals and there are different types of splitters for different uses. You should use a splitter close to LNB and it should have a low signal loss and must have bidirectional pass through. Go to eBay or many other satellite sources and you will see appropriate splitter for the job in hand and some come with built in ampliflication. |
Silver Member Username: TherepoFtaview.com Post Number: 203 Registered: May-07 | CATV splitters don't work properly with satellite. DirecTV type splitters are for a different technology, won't work with FTA. Don't use "splitters" for FTA, plain and simple. |
Platinum Member Username: NydasPost Number: 12343 Registered: Jun-06 | therapo: You are a technically savvy person. I do not wish to get into an argument with you. However, splitters or amplified splitter are used Descriptions abound everywhere to be used close to LNB and must be bidirectional with two DC voltages passing through, etc. |
Bronze Member Username: MeishaPost Number: 54 Registered: Aug-05 | Guy Sorry for the Delay but i got my answer from Plymouth and my boxes are working great, |
Gold Member Username: Saqeeb9000Post Number: 4001 Registered: Oct-07 | plymouth and nalin rocks keep up guys.. |
Bronze Member Username: Fakeman1Germantown, Maryland USA Post Number: 71 Registered: Jul-08 | sada, I see that you and Nalin are tight again. At the end of last year when he told you how to download your receiver and killed it you cried like a baby and called him every name in the book and got banned. Now you are saying that plymouth and nalin rocks. But why Ply mouth? like you said before he is a white man. Here is what your friend Nalin Nyda had to say about you. Nalin Nyda Gold Member Username: Nydas Post Number: 4469 Registered: Jun-06 -------------------------------------------------------------------------------- Tony D: Sada has had many "dead receiver" of different brands. He is also a great poster of profanity and was recently suspended from this site. Try and think rationally. Hundreds of people have the new BIN and there are no big horror stories anywhere. Totalffta.com is the semi-official site for the Viewsat BINs, and the same BINs are posted in at least 6 other sites that I know of. I was hoping to avoid having to bring up the issue of clone Viewsats. However your posts suggests to me that you had it working with the new BIN and it was working before. Therefore it is not a clone sada Bronze Member Username: Saqeeb9000 Post Number: 57 Registered: Oct-07 -------------------------------------------------------------------------------- Nalin Nyda is stupid... he doesn't know what he is talking about..... Tony Ur reciver is dead ..dead.. u have to gtag it ... u need to get some stuff to gtag it... its not plug and play thing.. just check there is a post here some where where it tells you how to gtag it.. best solution would be give it to some sat guy who knows the stuff. so he can repair it for you.. i don't know what's happening but even if u download from totalffta.com.. it has virus.. it will kill ur reciver.. if u have viewsat clone... but i also heard about the origianl recievers too. they have same problems.. viewsat guys were doing really good for last couple of years now they are doing the same thing as other guys.. don't know if i should trust fta anymore.. + word of wisdom.. and quote ""don't listen to Nalin Nyda"" |
Gold Member Username: PlymouthCanada Post Number: 4821 Registered: Jan-08 | Thank meisha All basher you look like idiot now. Hahahahahaha |
