Bronze Member Denver, Colorado USA Post Number: 38 Registered: Feb-07 | I had a dish network guy come and install new dish 500 plus with switch DP 34. I spent good 4-5 hours reading various forums on how to setup pansat so that I can get channels from 118.7, 119 and 110. I see echostar 7 in the list. I did a blind scan but it comes back with zero results. I am using 11250 and lnb local fre, lnb type as dish pro and standard both. Signal and Quality changes depending on the tp. I tried doing blind scan, tp scan but it does not return any results. I don't see Anik-F3 in my SAT list. I added new SAT with that name but don't know what to add for lower freq etc. I used some freq listed in some forums. How do I add all tps required. Why does the EchoStar 7 does not pick up any channels at all. When I connect the original DISH Network receiver it shows 3 sat: 1a and 1b - 119 2a and 2b - 110 3a and 3b - 118 I tried to change the DisEsq from 1 to 3 few times but with no luck. Can you please help me resolve this problem. I am in Arizona |
Gold Member NO Bashing Post Number: 2968 Registered: Oct-07 | post your antenna settings for all 3 satellites here so we can help |
Bronze Member Denver, Colorado USA Post Number: 40 Registered: Feb-07 | I am in the office now. I will go and do this again this evening. |
Bronze Member Username: Solano2008Toronto, Ontario Canada Post Number: 28 Registered: Nov-07 | i have dish 1000 and i am not getting any international channels on my FLU i have 110, 118, 119, 129 on my dish receiver but on flu i cannot find AnikF3 please help |
Gold Member Username: PlymouthCanada Post Number: 4344 Registered: Jan-08 | tell me true Nalin can answer you but as you can see many troublemakers bash Ecoustic Sorry |
Bronze Member Username: Solano2008Toronto, Ontario Canada Post Number: 31 Registered: Nov-07 | Ply mouth please help me to add Anik F3 in my FLU converted |
Gold Member Username: PlymouthCanada Post Number: 4404 Registered: Jan-08 | tell me if you have special LNB for 118.75W? |
Bronze Member Username: Solano2008Toronto, Ontario Canada Post Number: 32 Registered: Nov-07 | no i don't have any such LNB as i said earlier that i have dish 100 and dp lnb on it installed by dish network |
Gold Member Username: PlymouthCanada Post Number: 4412 Registered: Jan-08 | You must have a 30" dish and a this LNB http://www.mxmart.com/index.php?main_page=product_info&products_id=126 |
