No Signal on my veiwsat for bell
Username: Meisha
Post Number: 17
Hi
I have a viewsat extreme connected to 119 and 110 and fully working. I am trying to get Bell, but when i connect the cable to my diseqc i am not getting signal,, It is jumping aroung and the quality also, I have replaed the cable and Diseqc switch and still getting the same thing,,
I have bell Dish and dishnet LNB,, i know that is not the problem. I have been working on this for the past 2 days, and i am running out of Idea,
My fellow satellite friends do you have any other suggetions??
Username: Nydas
Post Number: 11257
Going from 119/110w to 91/82W.
All that is required is to swing the dish 28 degrees to the East and adjust the vertical elevation slightly. Common problem is to halt after turning 19 degrees only.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2926
Meisha
When you try to track a sattelite and quality goes up and down thats because you are on linear signal(bad satellite)like AMC 3 or Galaxie 25
Username: Meisha
Post Number: 19
if i unplug the cable those signal keep going up and down.. it is like more LNB is not connecting to my receiver
Username: Plymouth
Post Number: 2942
Meisha i have a motor on my dish and if i select a linear satellite with a circular LNB the signal goes up and down, you can trust me.
you are on bad satellite or a three interfer between dish and sat
Username: Meisha
Post Number: 20
plymouth,
do you have an email address that i can send you a video of what my receiver is doing when it is hooked up to 91/82 and when it not hooked up ????
Username: Plymouth
Post Number: 2953
Meisha
Sorry but i never give my email, but you can use Upload Image or Attachement
Username: Meisha
Post Number: 21
I cant upload the video,, it is too big
Username: Plymouth
Post Number: 2960
Put it on Box.net and put the link
Username: Pal33
Wpg, Mb Ca
hi i just bought vs2000 ultra, but i can't get all channels on 61.5, i am only getting etc alpha (622). i have signal but not quality on other channels.
i would appreciate
thanks
Username: Plymouth
Post Number: 2961
Paul singh
Where are you locate?
If you are in west and middle west, you need bigger dish
Username: Pal33
hi plymouth,
i in winnipeg, mb
Username: Meisha
Post Number: 22
Hey Plymouth
Here are the links
File2 - is connected to my Diseqc swtich http://www.box.net/shared/dmpii0j4so
File 1 - is not connected to my diseqc switch http://www.box.net/shared/8amkaua2os
Username: Plymouth
Post Number: 2967
Pal you need a 31" minimum
Username: Plymouth
Post Number: 2968
Meisha you have a problem with connector on Cable.
reinstall all Connector on cable between LNB and Receiver or try new cable.
That can be the LNB in trouble too
Check if inside wire on connector is OK, it must be equal with connector
Username: Meisha
Post Number: 23
I have replaced the cable and i have put the LNB on other dish and it works fine
Username: Meisha
Post Number: 24
Thanks Plymouth I got it working, I had to reinstall the cable and make sure the sliver wire was not touching the copper wire.
Username: Plymouth
Post Number: 2973
Meisha
Good news
I experiment this problem too.
Good connector and Cable are the key
Username: Codigies
Post Number: 10
hooked up my viewsat ultra and pulling good signal on port 1.trying to pull 110 and 119 with one dish,dual LNB.using ports 2 and 3 and can only get 110 to show up.how do I get both??
Username: Plymouth
Post Number: 2994
Use this tool for aligned your dish
http://satcalculator.freehostia.com/
