I think the receiver I have is a converted2700 Puff.
All I know is that I upload latest known working PUFF bins into it then it should work. But for some reason in the last few days it is not working anymore.
The problem I am getting is "Scrambled or Bad Channel". I get this when 276v2 PUFF was suppose to work and I am getting this now with 279PUFF bins.
-Signals from sat is strong (80%+) -I noticed when I go check the keys on the receiver for DN/ku6 I see FFs on the 2nd half of key0. So, maybe thats part of the problem. -I turned autoroll for DN off, set factory default key , reset receiver, and manually entered key0 and key1. but all I get is Percentage keep rolling up(up to 410%) for "receiving pictures".
put that 279puff back in and then did a blind scan.
the channels are working now but I am not getting as many channels as before.
my receiver is connected to the BellVu(nimqu?) and DishNetwork(ku7) sat outside the house. when I did the blind scan, it said Sat82 only. not sure the difference.
should I do a more through scan to get more channels?
