Silver Member Username: Pathfinder191
Post Number: 403 Registered: Mar-06
Posted on Hi everyone, SV 1000 does not update epg on some of 61.5 channels e.g. B4UMU, Star+ and couple of more. I reset the power but all it shows is no info. Any ideal? |
Silver Member Username: Mucho
Post Number: 417 Registered: Dec-07
Posted on Sam Check time setting. |
Post Number: 404 Registered: Mar-06
Posted on If time setting is wrong, it will messup the whole epg, not few channels. |
New member Username: Picanha
East LA
Post Number: 6 Registered: Jun-08
Posted on /P: Attached are channels for each DN/Bev sat you may use for complete EPG population. EXTENDED EPG: Using any of these channels will give extended EPG data for any/all DN sats. 119w ESPNA--145 WGN--239 FOXMW--418 CSNMA--424 FOXCN--427 FOXN--436 SNY--438 NHL--544 NHL--550 NHL--552 NHL--554 NHL--557 NBA--572 MLB--627 MLB--636 WGN--881 AUD19--946 SKDL--5802 EPSK1--5814 SIRI--6001 SIRI--6008 SIRI--6014 SIRI--6021 SIRI--6026 SIRI--6027 SIRI--6028 SIRI--6035 SIRI--6040 SIRI--6060 SIRI--6071 SIRI--6073 SIRI--6074 SIRI--6077 SIRI--6080 SIRI--6086'Regular' EPG If you don't have 119w, the following are lists for each individual DN sat: 61.5w/148w PLSAT--607 TVN24--609 RTPI--615 GEOTV--620 NBN--778Code: 110w BIOGR--119 VH1CL--163 MLTRY--195 HBOLT--309 SHOCS--321 TMC-W--329 TMCXW--330 FRESH--499 TMC-W--898 TMCXW--899 129w SPRKY--257 INFO--258 INFO9--259 SPRKY--5840 INFO--5841 INFO9--5842 WJET--7041 WSEE--7042 WICU--7043 WFXP--7044 WQLN--7047 WAHU--7932 D1000--9901Code: 105w D105--7000Code: 121w PLSAT--733 TVN24--734 KINO--737 RTVI--738 ALJAZ--761 MBC--766 118.8w GEMNI--799 SURYA--800 D118--9903 These next two are for ExpressVu. 82w FAIRM--716 FAIR--717 FAIRW--718 ABCHE--816Code: 91w 162 VuF2 167 VuF7 218 CHCH/Hamil 240 GLB/Edmont 280 NBC/Boston 296 UPN/Boston 352 Vu2 357 Vu7 410 The Score 510 BBC World I hope this will clear up any uncertainty on which channels maybe used for best EPG population. Note: Remember to add 1000 to the ExpressVu channel number if you use Bev channel renumbering. __________________ |
