Help with w119
Username: Fastbeatz
Post Number: 272
hey im trying to scan for 119W to get espn but im not getting anything...no ppv no espn nothing ....how can i make 119w work i have 110w working fine please help me
Username: Mucho
Post Number: 298
Hey fast
Try this,
A) Plumb your Mast, It MUST be vertical in all directions.
Uploa
B) use a compass and clinometer to determine a clear line of sight to Echo 7
@ 119.o*W.
Username: Tapeman
New York City in-HD, NY
Post Number: 2824
No need for compass
Yo can do both without moving dish at all
Yo need 2 LNBs
1- LNB for 110 and 1-LNB for 119
- Yo can strap a second LNB on same bracket mount
However facing the dish for east coast
119 has to be slightly higher than 110
Reference:
https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1496494#POST1496494
Username: Fastbeatz
Post Number: 274
ok..im on the west coast..so i have to raise LNB for 110W??
The actual problem is that im not getting 119W...if i look at my antenna settings when i put it on 119W it gives me a verry good signal for 110W.....its some how getting 110W instead of 119W....
but when i go to the antenna setting for 110W it works fine...it is getting the signal from 110W...
So i think i have to move the LNB that i use to get 119W ....so i can make it get 119W not 110W...
if you have anymore info that might help please tell me...and which way should i move the 119W LNB to get 119W???
Username: Mucho
Post Number: 306
OK Mr. King you are always running with the mouth, now tell the man what he needs to do. Don't run off.
Username: Tapeman
Post Number: 2829
From what I understand
Yo got one dish, one LNB for 110
110 working fine
Now
What I say don't move the dish
Yo need to add on 119
So yo need to add a second LNB on the right side of 110 facing the dish just like photo above
Next step
Yo need either to skew the dish or lower 119LNB since yor on the west coast
- skewing dish for west coast will be simple twisting dish plate from behind the dish few notches counter clockwise until yo get Q-signal
If like yo saying still getting 110 not 119
This tells me yo are combining 2 sats on faulty switch or not enabling correct DISEqC port in Antenna Setup
So insttead of me guessing yor hardware
List all hardware in full detail
When I say list hardware I mean don't give me stories just list all yo got
Dish, LNBs, Switches, Cables, Receiver name, current settings, etc.
I can get yo up and runing in few seconds
Good luck
Username: Mucho
Post Number: 308
fast beatz
Username: Fastbeatz
Post Number: 272
Posted on Monday, June 09, 2008 - 02:38 am:
Hey King you are telling the man that he
needs to add a second LNB on the right side of 110 facing the dish just like photo above, he said that he has scan 119 you think he used his dick.
Username: Tapeman
Post Number: 2831
He is green
It's hard to tell if he moved the dish or trying to get 2 birds with one LNB or faulty switch or even not enabling correct port
Based on what he provided can be anything
So if I tell him add an LNB and he already had one he would say I did
Relax Hawak
Yo ain't my enemy
There is only one common forum enemy here
That's Jimmy
But I will run him out before he get to anyone else
Username: Donnie1973
Post Number: 3029
disecq settings on reciever (and disecq switch if using one)
119= disecq 1
110 disecq 2
u have these wrong.
Get 110 in as u have, then move the skew till u get 119. It may take some one to watch the signal strength. But u will get it with patience
Username: Fastbeatz
Post Number: 276
ok..im going to skew the dish or something...i will watch the signal inside...
ok so i have 2 lnb for that dish 1 for w110 and the 2nd for w119
w119 is on port 3 and w110 is on port 2
i have intl channels on 97w with other dish on port 1
ok so the only one not work is the lnb for 119w...i think i need to move/adjust it or skew dish...i'll see what happens
Username: Tapeman
Post Number: 2834
Now that yo provided additional info
If I were yo I go 119 straight to receiver
Bypass switch using a couplar instead
As yo get good signal change back to DISEqC port
This eliminates possibility of wrong settings along with skew
counterclock wise is wheat yo need to skew
Username: Fastbeatz
Post Number: 277
ok never mind...i have 2 LNB's but i am only using 1 LNB for both w110 and w119.....
w110 - port 2 - gets w110 very goo quality and signal
w119 - port 3 - gets w110 instead of w119 idk why...
what do i do?
Username: Tapeman
Post Number: 2836
"what do i do?"
Yo can't do both 110 and 119 on one LNB without a motor
Or add a second LNB and skew it as I indicated above
Username: Fastbeatz
Post Number: 278
i cant skew the 2nd lnb because it is attached to the 1st one.... and i ha d 119 and 110 on same lnb working before....but i had them on different ports...what is a motor??
Username: Metallica
Post Number: 777
What is motor??
http://www.sat-sales.com/moteck_sg2100_satellite_dish_motor.php
Username: Mucho
Post Number: 309
Which twin LNB do you have?. A) has built in switches, so each port is capable of sending 110/119 down it. Since you have only 1 rec, just hook it directly to port 1, run check switch, activate rec and you're good to go. Assuming that you have the dish peaked.
A) Upload
B)Upload
Username: Tapeman
Post Number: 2837
If yo can't skew LNB yo skew dish plate
If yo can't skew dish plate yo skew LNB
If yo can't skew either then it's time to buy a new dish that can be easily skewed
If this is not a new installation and yo had them working before then it must be yor LNB port assignment in yor antenna settings somehow got changed
Username: Zizo
Post Number: 51
Hi,
I have the satellite 118 now. Is there any solution to get also the 110 and the 119 on the same dish?
Thanks
Username: Tapeman
Post Number: 2841
Yes there is
But create a new thread
List all yor parts like LNB, receiver, dish etc.
I'll help yo
Post Number: 3030
u cant get 110, 119, and 61 with two lnb's without moving them. U never had it working that way before with this setup. U are getting all u are going to get. enjoy
Username: Tapeman
Post Number: 2842
WTF
nobody says 61
Please don't smoke more than one pot a day
Smoking pots and FTA are not very good combinations
Username: Mucho
Post Number: 314
Zizo
YES you can
We are like Home Depot
You can do it
We can help
Username: Rtf
Post Number: 50
How do you smoke a pot?Upload
Username: Mucho
Post Number: 317
Username: Nydas
Post Number: 10918
Zizo Zizo: For many persons from the East, your quest is the most legitimate quest.
The answer is " Yes, You can get 118.7,119, and 110W, all using one dish"
Your dish has to be 33"-36". You mus use one special LNB like a CB2008A for 118/119 and another standard LNB for 110W. The CB2008A has two outputs for two receivers, and EACH output will give you both 118 (Anik 3) and 119 (Echo 7). You will most likely need to modify a bracket to house it. The LNB for 110W (Echo 8,10) is a standard LNB with two outputs for two receivers. Add two 4 to 1 DisEqC, and you should be able to get two receivers attached to these. DO NOT go for DishPro LNBs, unless you want to go the Dishpro route and buy official kit for Dish for about $110 (This is OK, if you had a large dish for 121W and are now rethinking).
White Hawk has posted a good picture above, and, as I said, your only minor problem will be mounting the LNBs properly and securely.
Don't listen to anybody who suggests doing it with a dish under 30" in size. It might work for a while marginally and with the first electrical storm you will get a black out on 118. Make sure you get the proper LNB for 118/119 - this is a Universal or a circular LNB specialy designed to receive 118/119 combo on one LNB, and using one input port of a DisEqC switch.
Username: Cdeepak
Post Number: 33
110+119 works on same dish but you will loose quality on either one of them.
In order to get best quality signal from 110 and 119 I am using seperate dishes.
I had dish network people who installed dish everytime I moved and everytime either one of them had quality only 50%
Now I get 80-90% quality on both of them with seperate dishes.
PPV movies and 499 stuff works at almost DVD quality with seperate dishes.
Username: Fastbeatz
Post Number: 279
White Hawk
Username: Mucho
Post Number: 309
Posted on Wednesday, June 11, 2008 - 08:28 am:
A)
B)
RE: White Hawk---- u asked which one i have from those pics...its the 1st one (A)...but for some reason i only use one lnb to get both 110 and 119 but im only getting 110 ....119 shows up as 110 some how its getting 110 instead of 119...do u know y?
Post Number: 3031
sorry king, he said internationals on 97.
let me revise...
u STILL cant get 97, 110, 119 with two lnb's without moving it.
Better??
u can get two, but not 3. Add an lnb and u can.
