New satellite box?
Username: Zunna
Post Number: 240
i want to buy a new satteliete box i heard ther is one with the internet connection and it doesnt go down tht much..can someone suggest me a good box which one should i buy?
Username: Burkan
Post Number: 103
I just bought the SonicView 360 primer, it has good support and PVR with external Hard drive.
Nfusion is the box that updates on the net.
I did not go with them since they screwed us up by stopping support to their other boxes. Satcruiser.
Username: Zunna
Post Number: 241
does Nfusion automatically updates new bins?
Username: Vittu
Post Number: 230
Zunna, yes it will update automatically and also give you the option to update new bin when ever tv goes down.
Username: Zunna
Post Number: 243
ya but will i have to download the latest bin. how will it work automatically? and how often does it go down?
Username: Vittu
Post Number: 231
As far as I know, it goes down for a few min/hours when everyone is down for days. You will only have to manually load the bin the very first time after purchasing the box since it doesn't come flashed and afterwards it's all auto process.
Username: Lol
Post Number: 670
Kate rents Her Box out but I'm not sure it would qualify as new by any means .. If you Know what i mean rumor is it smells like fish
Username: Rockman169
Post Number: 30
i just sent for a 360 primer but what does it mean by external Hard drive to use the pvr. the thumstick that you put files on with thanks
Username: Dimwitt
Post Number: 761
king turdmuncher will be here to help yo soon.
