119/118.7 and 110 on 1 dish
Username: Way2smart
Www.Desifta.com
Post Number: 1622
ok so i got a 18x24 dish and 119 is working fine with 55 to 65 quality and 80 signal.....however 110 is low on quality(30 Q)...any was to fix that?
thanQs
Username: Kirankumar
NO Bashing
Post Number: 2834
you need to adjust your skew
go to www.dishpointer.com and look under multiple lnb's for skew and elevation
Username: Vittu
Post Number: 226
so you are getting 119/118 on 24X18?
Username: Way2smart
Www.Desifta.com
Post Number: 1624
vittu.....im using 18x24......i got it working i was using the 110 on the wrong side...
Username: Fastbeatz
Post Number: 275
what do u mean on the wrong side??? im having some problems picking up w119..do u think i need to move it a lil?}
Username: Tapeman
New York City in-HD, NY
Post Number: 2827
Slight dish adjustment or skew
Or a little bit of both
Username: Way2smart
Www.Desifta.com
Post Number: 1625
no i mean it takes 3 lnds so i had the 119 and the middle one was empty and the 3rd one had 110(is spouse to be 101)
Username: Tapeman
Post Number: 2830
2 LNBs
1-LNB for both 118/119 (11.7G to 12.7G)
1-LNB for 110
Space will be most likely for 105 for certain local regions
Username: Vittu
Post Number: 234
you are the first one to confirm that you can catch 118/119 and 110 on 18X24. Thanks man!!! I am out to get the new lnb that will catch 2 birds with 1 lnb (118/119) Everyone else said, I need a 33" Dish to catch 118 :-)
Username: Vittu
Post Number: 235
I currently have 110/119/129 setup on 18X24 using 5 lnb holder bracket. I will simply replace 119lnb with 118/119 lnb.
Username: Tapeman
Post Number: 2835
Size of dish depends on yor location
If yor up in Canada yo'll need a bigger dish where as if yo are in midwest 20" can do
Username: Way2smart
Www.Desifta.com
Post Number: 1626
vittu ur not ganna get it the signal like that....if you replace the lnb u have to lock the signal again.........if you dont it not ganna work......to lock the signal you need a satfinder......so well ur at it get a satfinder around 19$...Good LUCK
and im in canada(king tapeman) so vittu no problem.........
for more questions come to [link removed]
Username: The_coders
Post Number: 1371
Username: Gregraf
Post Number: 797
