Vs ultra froze wile dl new files
Username: Jmonte
Havana, CUBA Us
Post Number: 9
need help, my vs ultra froze as i was down loading latest file with flash drive.
dont want to power down what can can i do.
any advice is appreciated.
Username: Kirankumar
NO Bashing
Post Number: 2787
remove flash drive
Username: Nydas
Post Number: 10696
You may have to load factory BIN using cable and Loader, and then reload the latest BIN
Username: Jmonte
Havana, CUBA Us
Post Number: 10
thanks ,i heard froze fix is also good
Username: Way2smart
Www.Desifta.com
Post Number: 1616
yes it freezes use the cable.....i loaded mine with usb but froze then used cable working fine
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2400
j monte
Load this mainpg.pgm with cable
http://www.box.net/shared/ytdcaz604o
After it load last bin
Good luck
Username: Jmonte
Havana, CUBA Us
Post Number: 11
THANKS PLYMOUTH WILL GIVE IT A TRY
Username: Kingofdakingz
Post Number: 258
thats what i did yeaterday my receiver frozed and what i did was i loaded the latest factory bin and then i loaded the latest bin USING NULL CABLE (NOT USB IT WONT WORK)
Username: Rtf
Post Number: 47
try a hard reboot before you upgrade using USB.
Username: Hawaiian_time
Kanaka freak...
Post Number: 1903
Seems this latest bin for the ultra problem affects some of the receivers. It won't load no matter what you try to do. An older bin will load normally after you flash the ultra with a factory bin. Hopefully a new bin will come out that addresses this problem.
Username: Plymouth
Post Number: 2406
Warning, if you use factory bin from Viewsat.
Thats why you freeze, this bin is corrupt
