How do i get star + and star1 on my Pansat 3500SD
Username: Sshaniga
Post Number: 9
Hi,
How do i get star + and star1 on my pansat 3500SD. I have dish angles 110/118/119/121
Please give me complete setup details.
thanks
Username: Kirankumar
NO Bashing
Post Number: 2642
i don't know much about pansat but i guess if you rescan 118 those channels should appear on 716 and 718
Username: Sshaniga
Post Number: 10
Thankyou, but do you have the info of the TP which I can scan on 118.
NO Bashing
Post Number: 2643
star + is on 12326 and
star 1 is on 12414
Username: Sshaniga
Post Number: 11
I Just scanned those TPs by adding it to my setup in all of the following , but I didnt get the channels 716 and 718. Is there something wrong which I am doing. where do I need these TPs to ?
echo start 7 119
OCS-DP
LnbFreq 11250
TP Fre 12239
Disq Port 1
echostar 8,10 110
OCS-DP
LnbFreq 11250
TP Fre 12224
Disq Port 2
echo start 118
OCS-DP
LnbFreq 11250
TP Fre 11250
Disq Port 3
Username: Khopdi
Post Number: 115
For testing purpose, make sure your settings are correct. Do this.
Menu-Installation-select 118 (only)-select LNB (make sure frq is 11250 and port is correct for 118)- press OK (not exit)- press menu-do sat scan.
