Earthhour*blogspot warning
Username: 360guy
Ottawa, Ont Canada
Post Number: 74
This idiot will send you to a site that you can't even back out of. Has nothing to do with FTA
Username: Kart_57
South Florida
Post Number: 77
Site will lock up your computer!!
Username: Partner500
Post Number: 22
Lies. USE THE SIDE NAV BAR
http://www.earthhourblog.blogspot.com
Username: Carburante
Post Number: 82
PHUCK U JOHNNY LIE
Username: 360guy
Ottawa, Ont Canada
Post Number: 78
I've suggested it elsewhere but will repeat it here. If anyone is asked about Earthhour you should inform people of the nature of those who are involved in it. You know, their tendency to lie, misdirect and have no consideration or appreciation on how their behaviour effects others. Kind of ironic given the cause they are putting forth.
Get it Johnie!
Username: Adirondak
Post Number: 11
Johnie,
I am posting this snapshot of the side nav bar.... either you are blind from all the jerking off.... or you are a chunky load of smegma that you mother should have swallowed.... I vote the latter.Upload
Username: Postergirl1
Post Number: 300
pos johnny
Username: The_coders
Post Number: 921
Username: 360guy
Ottawa, Ont Canada
Post Number: 81
Great use of the word smegma. I've been waiting for an appropriate time to use that myself but you sir have definitely used it correctly.
Username: Gregraf
Post Number: 179
