New member Username: Partner500Post Number: 7 Registered: Apr-08 | visit http://www.earthhourblog.blogspot.com for more info on this! |
Silver Member Username: Ustaad_hcPost Number: 590 Registered: Oct-06 | |
Bronze Member Username: SuperslammyPost Number: 60 Registered: Sep-07 | Bullcrap....no updates from official sites you moron. |
New member Username: Partner500Post Number: 10 Registered: Apr-08 | No. I DONT LIE Pansat 2500-2700 conversion has new EPG just check it out http://www.earthhourblog.blogspot.com |
New member Username: MightyquinnPost Number: 1 Registered: May-05 | Johnniy Doe is a total @sshole. I went up to HIS site and read EVERYTHING. All there is is Earthday crap with nothing else. For being such an @sshole, no one should bother going to your site you jack@ss. What a sorry@ss way to try to get people to go to your site. All it does is piss people off that you misled them. |
Bronze Member Username: Westway11Post Number: 75 Registered: Aug-07 | I found the info helpful, just scroll to the left side nav bar http://www.earthhourblog.blogspot.com |
Bronze Member Username: 360guyOttawa, Ont Canada Post Number: 75 Registered: Dec-07 | Found it helpful, huh? Especially the promised Pansat fix? There's no way you're connected to the f*ckin'goof right? |
Bronze Member Username: Westway11Post Number: 76 Registered: Aug-07 | Sorry, I was hitting the wrong site. I didn't see that the address bar was different. That site is bogus. DO NOT GO THERE |
Bronze Member Username: OpieDEEP SOUTH Post Number: 51 Registered: Dec-07 | Jonnie doe -- FUDGEPACKER |
