Username: Jaz06 Post Number: 100 Registered: Nov-06
Monday, April 14, 2008 - 14:22 GMT My international channels keep autorolling every 5 minutes. Anyone else...
Username: Kirankumar NO Bashing
Post Number: 2468 Registered: Oct-07
Monday, April 14, 2008 - 14:28 GMT do hard reboot,turn off and on from back
Username: Jaz06 Post Number: 101 Registered: Nov-06
Monday, April 14, 2008 - 14:30 GMT None of the other channels are freezing though (110/119) bit weird isn't it?
Post Number: 2470 Registered: Oct-07
Monday, April 14, 2008 - 14:33 GMT the other thing is you might have a loose connector on internationals or moisture in that cable,check it out make sure to turn box off before unhooking or hooking up cable or switch
Username: Nydas Post Number: 10155 Registered: Jun-06
Monday, April 14, 2008 - 15:40 GMT If internationals are on a separate dish through a switch, the problem is your switch.
Username: Hshakarchi Post Number: 219 Registered: May-06
Monday, April 14, 2008 - 20:09 GMT I am having same problem here with some internationals for now, I am using (61.5), this has happened before, I think we should wait for a new fix.
Username: Saaju Post Number: 18 Registered: Sep-07
Monday, April 14, 2008 - 20:32 GMT its happening to me too:p wait for new files!!!
Username: Khankhan Post Number: 15 Registered: Dec-07
Monday, April 14, 2008 - 23:38 GMT i am having the same problem
Username: Arctick Post Number: 32 Registered: Mar-07
Tuesday, April 15, 2008 - 00:01 GMT I am having the same problem only with international channel. I don't think the it has anything to do with Switch issue. its the newest bin that is causing problem. I have vs 7000PVR.
Username: Frobi Post Number: 206 Registered: Aug-06
Tuesday, April 15, 2008 - 00:09 GMT VS extreme and CW600P both freezing. Nothing to do with bin.
Username: Lolol Post Number: 287 Registered: Sep-06
Tuesday, April 15, 2008 - 00:28 GMT its happening on all international channels seems like there is an ECM on the way pretty soon here.
