CW800 channel freeze every 3 minutes
Username: Moly
Hi All...
I am using C800 PVR and I have this problem:
The reception freezes every 3 or 4 minutes for about 30 seconds and i get the message of "channel scrambled" at the top of the screen. VERY irritating. Any ideas on how to solve this problem.
Username: Kirankumar
I will not b...
Post Number: 2094
have you tried to hard boot ?
switch off from back and switch on
Username: Moly
Thanks for the reply African.
Yes, I have tried the hard boot and re-uploading the bin as well... still.. same... every three or four minutes it freezes for a minute or so
Username: Brucester
Post Number: 1348
hello moly try this do a factory defalut then put in the seating for your sat and rescan sats inabble the patch f1 000 and this will help
Username: Brucester
Post Number: 1349
and what bin are you using bin154 is the new bin out for cw800s
Username: Moly
I think the one i am using is 1.54
thanks a lot for the advice, i will try it and let you know how it works out...
Username: Brucester
Post Number: 1353
any time mole your welcome
Username: Federico
Montral
hola
Username: Moly
another question: what is a reliable site to download the bins from?
Username: Brucester
Post Number: 1354
crazyfta dot com most of the time i put the bins in so ther safe and free just regester and we have live chat to help you faster hop to se you there and hope your boxes is runing better if not let me no thanks
