Level all over the place on Pansat 3500sd
Username: Miamihitman09
Post Number: 100
My lawn guys screw up my cable and I trying to set up everything up again. My level is jumping all over the place? the level is going from 33 % to 83 % to 99 % and then it start all over again? How do i fix it?
Post Number: 103
Can anyone help with this? is it the cable?
Post Number: 104
Can anyone help? PLEASE
Username: Flu_guy
Post Number: 48
Eric garica:
Well, I would say the first place to check would be your cable, inspect it carefully for any nicks, cuts or other damage that may have occurred. Is it very long? if there is any doubt, it might be easiest buy another length, hook it up temporarily and see what happens. Remember to turn off your STB at the back before disconnecting it, else you may damage something.
Htiek
Post Number: 106
Htiek, dumb question but what is STB? I inspect the cable and it is good. I tried other cable same problem.?
Username: Flu_guy
Post Number: 49
Sorry, STB. = Set Top Box, your Pansat 3500
Username: Rtap
FL
Post Number: 1892
your problem is th c13,c14 capacitor
Username: Rtap
FL
Post Number: 1893
eric sorry ,first replace cable check your settings,then if all ok open the 3500 and check these capacitors
Username: Flu_guy
Post Number: 50
What sort of setup do you have, just one dish, one LNB, (the eye thing) and what sat(s) are you pointed at, tell me more?
Post Number: 107
I have one 500 Dish with 2 LNB. I am pointing at 110 119. What i'm i looking for with the capacitors??? how do i know if they are good or not??
Post Number: 109
How can i test to see if the 3500sd is the problem and not something else?
