Level and quality problem
Username: Aznprelude
I have a pansat 3500 and out of nowhere the level and quality starts to jump up and down from 50 to 80 and now I have NO level and no quality.. no signal. But i do get level on amc antenna what ever that is, but not quality. I tried factory flash and then loaded the feb 14 bin and still no signal. I checked the satellite and it was not moved. HELP.
Username: Luser
Post Number: 68
Have you checked you antenna settings they can change on ya and thats when I usually see the level bounce.
yes I have and there still the same... but the level is not bouncing anymore, it's staying at 20% now. Do you think its the box?
Username: May_queen
Post Number: 12
Check out the following link at future:
http://www.future-fta.info/Forums/showthread.php?t=50719&highlight=volume
Username: Rtap
FL
Post Number: 1869
rongrey OPEN YOUR PANSAT AND SEE IF CAPACITOR C13,C14 ARE OK.THESE ARE COMMON PROBLEMS FOR THE 3500.IF THE TOP OF THE CAPACITOR ARE LIFTED UP(BLOWN)THEN REPLACE THEM.GET THE PARTS AT RADIO SHACK.
Post Number: 7
ok I'll do that after work thanks
Post Number: 8
good to go. thanks may and rtap
