the nfusion can be used with belkin router... i would suggest using eithernet cable if you can .. if not you can go wireless... they use what is called iks wich is internet key sharring ... it sends signal to box .. and upgradeds keys from there ... i dont know exactaly how it works i just know that it works... had mine since november only been down maybey 2 hours all together ...
I'm not sure what you mean by hooking to your computer. The nfusion I have is hooked through XE102 's to my wireless router. I don't know anything about the neosat. The 102's plug into the wall outlets and work off your house wiring.
thanks bill i am trying to find out if i buy one oif i hook it up as say if it is going to have the same progamers as dn &bev and with bin that might go down
