My Viewsat Ultra is not working, with the new Bin... I tried putting manually but the menu DISH 00 01 00 doesn't exist only DISH 01 06 00 and i cannot put the keys manually. what can i do to fix this? Please help
the provider id have changed to 01 06 now no more 00 01..just let it autoroll for a few minutes and you will see TV. and make sure you got a new bin. PFTAUSW-080211U DN Fix
still Autorolling... my friend has the same box viewsat ultra and on his menu keys he has DISH 00 01 00 and DISH 01 06 00... and in my menu i don't see the dish 00 01 00 ... it's not normal...
I did VS Ultra FAIL FIX.zip and now i am blind scan channels because my viewsat is showing no channels... i will let you guys know if it works..thank you all for the help.. keep you posted
Thank you Nalin.. i did the fail fix and then the factory BIN v131 and scan the channels...put the last bin... Then i went to the manual Keys, and under NAgra the DISH 01 01 00 still only had 2 lines 00... 08.... I added 3 more lines for 09... 88... 89... and manually entered the keys..my friend gave me (he has the same box).. I really don't know what fix it..but i see TV now Thank you all for the tips... Chaoo!!
