Important-About Pansat New files.
Username: Nydas
Post Number: 8029
[link removed] has removed the latest Pansat files.
The following is from FTATALK.COM
About Pansat New Files. Read This !!!
This is a C&P
These new pansat files that r coming out they are not working !!! Also report from bl irc channel they dont even know why they was posted ...so thats why they are not here, they an't good !
Please don't post them here !!
We will keep you posted if anything else comes up.
list of bad files
hd-9000bl_080208_9056_api
hd-9200bl_080208_9242_api
x-6095bl_080208_3191_api
x-95bl_080208_3160_api
X_250BL_080208_V577A_api
x-88bl_080208_460eubx_api
x-87bl_080208_b75_249_api
x-05bl_080208_365_api_nocard
Username: Kirankumar
Kenya
Post Number: 1454
good post,
thanks Nalin
Username: Nydas
Post Number: 8038
Bump
Username: Ninjad
Post Number: 32
thanks for the info. just gonna have to wait
Username: Jagr1234
Post Number: 180
thanks
Username: Americanistar9
Post Number: 53
I know this is going to sound annoying. Ive just been gone for a while and well ive tried to read posts, but it just gets more and more confusing.
SO!
NALIN, is there a bin out for Pansant Converted? for DN???
Thanks! and sorry for the bother
Username: Nydas
Post Number: 8043
"NALIN, is there a bin out for Pansant Converted? for DN???"
N0...N 0......N 0 - Not in the last 72 hours or since the last DN ECM.
Post Number: 54
Thanks!
Respect to you
Username: Kacha
Post Number: 53
hi nalin,
are the files at public.box.net/2500_full_kit
working or no?
Username: Kacha
Post Number: 55
249t
Username: Derek_jey
NY
Nalin, same question. What happened to the file by
p...jvvh 249aio that you posted before lunch?
Username: Digger384
Those files are for bev only
Username: Kewonsc
Post Number: 23
running pansat 2700 A here got x-87bl080208_b75_249api.from future up and running.before download informs you UP for B3V and down for DN if that helps
Username: Domy
Post Number: 100
i try the 249 in bev that nalin posted before does not work in BEV it says can unavail to access chanel
Username: Nydas
Post Number: 8044
This is what I saw when I just checked
http://public.box.net/2500_full_kit
1. There is full_kit_249B.zip there with clear cautions in the Instructions file and suggestions to install either the the 235 (for BEV) or the 248 as a stand by.
For testers the 249 files are included in a subdirectory
"Alternative 249 for BEV-use at own risk".
2. All_249.zip with the all-remotes 249 and the Saif 249 for testers.
Username: Ndn3
Post Number: 139
pansat sucks...
BL is enjoying the weekend... I'm going to buy CW...
Username: Woohoo331
Toronto, Ontario Canada
Post Number: 25
i agree I am looking at an SV
Username: Leafs
Post Number: 466
keep checking www.ftasolutions.co.nr files will be posted there...
Username: The_coders
Post Number: 345
SPAM ALERT!
