Need Help With CS7100
Username: Shazz
Does anyone how can i fix my CS 7100
Every time I press On button I get message (preparing for stand by mode) ...
Anyone out there had similar problem that can help me....
Username: Kirankumar
Kenya
Post Number: 1469
that is exactly what that button is supposed to do.
the red button on your remote puts the unit in standby mode.turn it off from the back and turn it on
Username: Saqeeb9000
Post Number: 2207
just do a simple reset from remote...
press menu,inst,factory reset.. now download new bin again.. this should work...let me know if you still have problems..
Username: Shazz
I tried turning off back button. No matter what i do it wont turn on, it goes to stand by mode. No matter
how many times i press ON it always goes to stand by mode.
Kenya
Post Number: 1476
did you do what sada said.factiry reset?
try it and post again
Post Number: 2215
for my cs 6100 (2nd rec ) .. i had same problem.. factory reset worked...
Username: Shazz
How can i do factory reset if it wont turn on it goes to stand by mode in 1 second.
Post Number: 2218
oh oh... i think you download wrong bin or u accidently took off usb before u let it download completly.. in this case ...
go to any reputable website ..
and if you have that loader cable try to install factory bin using a loader and factory bin ( not with usb )...but with null cable...
Username: Shazz
Thanks I will try that. all i did left it on all night on one channel.
Kenya
Post Number: 1477
Sada,
i don't think 7100 comes with cable
Post Number: 2219
on my cs 6100 i have slot in for usb and on the back to download via cable.. i am not sure same thing fro cs7100
Username: Shazz
yes it does. it came with 1 gig usb and cable
Username: Shazz
Loading factory bin didn't do anything. Its still in stand by mode.
Post Number: 2225
did u able to load the factory bin properly.. did it went through..
Username: Shazz
Post Number: 7
Thanks it worked I forgot to unplug TV cables and LNB cable the first time .Thanks again all...
