Username: Way2smart Www.desifta.tk
Post Number: 1117 Registered: Oct-06
Friday, February 08, 2008 - 02:44 GMT ok so i want to get 118 using 119 for my ultra so i followed the steps and everything.....but still no channels... Setting up the Antenna Settings: Go to Menu, Installation, Antenna Setup Setup for Echo 9 -121W LNB Type: Standard LNB Freq: 10750 **** TP Freq: 11715 Now you will not see TP freq: 11715. In order for the Receiver to find all Available TP freq for 118.7, make certain you Auto TP is ON. Then do this: Preparing the TP Frequecies for Echo 9 -121W: Go to Menu Channel Scan Select EchoStar 9 Scroll down to Edit TP> OK Now scroll thru the window and delete all the TP Freqs by pressing the [F3] Delete TP button. Then, while in this window: Press F1 for Add User TP Enter: TP freQ: 11715...S/R: 20000...Pol: V...FEC: 7/8 Exit and then Save. Now go to Auto Scan: Auto Scanning all available TP Freqs and Channels from 118.7 (121W): Echo 9 should be selected, Scroll down and start Scan. You should now have over 123 Channels if your dish is 24" or larger. still not getting any thing........what is the special lnb.....for 118
Username: Saqeeb9000 Post Number: 2085 Registered: Oct-07
Friday, February 08, 2008 - 02:49 GMT why 121.. smart... it should be 118.8.... on sat name mine says 118.8.... its called anik 118.8.... just move your lnb a bit and u will get better signal if you don't wanna get 119.. i scanned 118.8 and i got few channels but no geo agg..
Post Number: 1121 Registered: Oct-06
Friday, February 08, 2008 - 02:51 GMT nooo sada for viesat its 121.....all the setting is on 121 thats what the viewsat coders did
Username: Saqeeb9000 Post Number: 2086 Registered: Oct-07
Friday, February 08, 2008 - 02:53 GMT ok but how are your signals .. qulaity..wise to 121..
Post Number: 1124 Registered: Oct-06
Friday, February 08, 2008 - 02:54 GMT i get 84 channels not sure......im not getting any then on the setting but when i scan it gives channels but r from 119.....or 148.... i think i need some kind of new lnb if soo which one????
Username: Saqeeb9000 Post Number: 2088 Registered: Oct-07
Friday, February 08, 2008 - 02:57 GMT ok first of all channels that are you getting are they are from dish 118,8,,, go to any one of the channels and press info ... it wil give you dish name ...119 or 118.8.. thats what happend with me.. i scan the dish and it gaves me 50 channels... but now if you are getting 118.8 why don't u do an advance scan.. put tp.pol etc..
Username: Saqeeb9000 Post Number: 2089 Registered: Oct-07
Friday, February 08, 2008 - 02:57 GMT but all depends on quality...how much qulaity are you getting
Post Number: 1127 Registered: Oct-06
Friday, February 08, 2008 - 02:58 GMT i need the tp for aag to geo so i can check but i dont think soo i need this special LBN
Username: Saqeeb9000 Post Number: 2090 Registered: Oct-07
Friday, February 08, 2008 - 03:01 GMT TP freQ: 11715...S/R: 20000...Pol: V...FEC: 7/
Username: Madflea168 Post Number: 213 Registered: Jan-08
Friday, February 08, 2008 - 08:34 GMT I did mine with 121, not 119 nor create a new sat. set freq 10750 (some said 10600) and add tp 11715. you may want to adjust antenna a little, after you add the tp and if you don't see any signal/quality you will not get much channels.
Username: Plymouth Quebec city,
Quebec
Post Number: 47 Registered: Jan-08
Friday, February 08, 2008 - 12:43 GMT If you the good LNB you just blind scan on 119W.I have a motor and fortec100 and i have created a new satellite 118.7 and blind scan.Work fine
