Nalin, Could you please let me know how can I change my sat from 148 to 61.5. Which side should I turn the dish? Please explain in details and thanks in advance. Secodly does 61.5 have Zeesports Aag and Geo News channels?
you will need a different lnb to receive from 118. there are a lot of q about 118 being asked in the forum.
I did mine with the dn repoint kit cuz my super d, and I ain't sure if the generic will work or not, dn=$100, generic=$20, will need to do minor adjustment to the antenna, and new setting to the box.
The only major problem for Torontoians is the weather. I did not know you can get 148w in Toronto. Anyway, the same dish and LNB can be used - just swing it to 61.5w - towards New York. The signal and quality is excellent. AAg is there. Geo is there too. If geo news is another channel then I do not now if it is there. Madflae is right about switching to 118.7 using a Universal LNB ($20) and a 30-33" Dish. That's why I mentioned the weather. It is easy if you already have a 33" dish pointing to 121 as he had. It is likely that in a few months they might vacate the 61.5W for HD (all rumours).
As aslways you are so candid and easy to understand. Thanks Nalin. So I can change to 61.5W. You are right weather is always trouble here. I'll try to change it on weekend end. Thanks again for your help.
Nalin/RTAP one more question. A friend of mine has Ultra Viewsat pointed to 61.5 but he is unable to watch most indian Pakistani channels except few. All he get there is Scambled Channel. Any advice please.
Use Blind scan (Power scan). Echo 3 (61.5W) should give a little over 130 channels on 7 horizontal and 6 vertical transponders. In antenna settings, use LNB freq. 11250 on a standard LNB, unless it is a peculiar LNB.
