No Disney channels
Username: Winterpeg
Winnipeg, MB Canada
Any idea why the disney channels are not showing up...I'm using a Pansat 3500
Username: Saqeeb9000
Post Number: 1892
whcich dish....
Username: Winterpeg
Winnipeg, MB Canada
110 0r 119 ... any idea?it should be channels 172 and 173 I believe...Dishnetwork
Post Number: 1897
12268 L
tp 4
SR 20000
FEC 5/6
Disney Channel West Nagravision 2
this is the freq, of disney channel on 119 dish u can do advance scan where u can put freq,etc ( i am not sure with pansat ).. or if you are missing only one channel just delete the 119 dish channels and rescan it.. or do a blind scan.. if nothing works do a factory reset, reload the bin and scan channel again..
Username: Winterpeg
Winnipeg, MB Canada
Thank you Sada, I'll give it a try. Almost sure it'll work.
